Pulling apart an FJ40 (79) axle
Discussion in '40- & 55-Series Tech' started by Blue60, Sep 16, 2003.
  1. Blue60
    Blue60
    606
    2
    Mar 16, 2003
    Hi All,
    I've done two complete axle/knuckle rebuilds on my FJ60s (had the factory manuals), but I just picked up a "winter beater" 79 FJ40 I need to do some work on. Since I don't have the factory manual, can anyone tell me how the OEM Warn Locking Hubs come off? I can't even get the faceplate for the locking hub body off! These allen bolts are tougher than cone washers. I've soaked with PB Blaster and heated with MAP gas...no joy! Do I even need to take the faceplate off to pull the hub off the axle? I need to put new rotors/calipers and dust shields on this thing... appreciate any advice! Hopefully I don't have to drill the allen bolts out...
    Dave
    P.S.
    Any ideas on cheapest exhaust solution from the downpipes (stock) to the tailpipe?
  2. cruzer
    cruzer
    586
    1
    Oct 18, 2002
    rebuild is the same as on a FJ60
    You need to get the allan head bolts out to get the face plate off, then it's the same as asian hubs...snap ring on birf...ect ect
    Have you tried using an allan head socket instead of just and allan key? may give you better leverage (say a pipe on the end of the 3/8s wrench) to get the studs undone. I just pulled apart a 76 that was a bear to get apart. If the hub is stripped out you can fix it by drilling and using a Thear Repair kit on the hub body to "rethread" the hole.
    HTH
    Stew
  3. woody
    woody Internet Fireman Staff Member
    10,331
    Media:
    303
    1,086
    Jan 15, 2002
    Toquerville UT
    I've had to drill out a couple....major PITA....
    You "might" get lucky and the PO forgot to install the outer-most birfield clip...but if they are that stuck, it's more likely they've NEVER been apart!
