Crawl should still work... though the system might get confused... not sure yet. I don't use the feature often, if ever, so not a huge concern.
I guess CRAWL would still work when the locker(s) are NOT engaged, but it would be impossible for CRAWL to brake one wheel on the axle when the lockers ARE engaged.
I think you may be confusing CRAWL with TRAC (or is it ATRAC on the 200 ... I cannot remember ... basically the traction control). They both are based upon braking, but CRAWL is closer to a low speed cruise control that modulates speed via brakes and/or throttle. The braking of individual wheels is the traction control system.
Easy to get crossed up since they are integrated and use the braking system.
Either that or I am totally confused it has happened before and will again ..
I just got my 200 and can't wait to try out Crawl mode
thanks for the heads up on that, so the speed is controlled by the switch on the center consol, correct? how do you do the terrain select?
