What part? Makes me glad I bailed on that one today.
After some additional inspection when I got home, the right side is definitely bent upwards a bit. Trying to figure out how to straighten this. Looks like a rock snagged the bottom and pulled it outward, which seems to have twisted the right side upwards a bit. It’s definitely bent above and to the left of the trailer plugHells Revenge rearranged my rear bumper. The right side swing arm isn’t quite level anymore (it’s aiming a bit up from the left side), the right side is obviously lower, and the whole thing is shifted about 1/2” right (the tailgate almost hits the left arm when open now). I’m hoping there’s some left-right adjustment I can make when I get home, as well as jacking up that corner, otherwise it means I must have bent the mounting brackets.View attachment 3612553
D’oh. As soon as you used the word weld, it’s beyond me. That does seem like the best option though (probably using the frame crossmember above the axle)I wouldn't pull on the trailer connector hole either, it will deform. Maybe tack weld a hook plate at the best spot, then come-a-long connected to the rear axle or frame.
I’ve considered this. I did try to aim for landing on a rock to adjust but kept missing them . I may try it but I suspect it’ll muck up the mounting point or snap those bolts before actually fixing it.Remove swing arms and then back into a rigid barrier at slow speed. Gradually "bump" it with more and more force (speed). Perhaps use a chunk of wood to localize force to the lower portion (below trailer harness plug).
Would at as a bigger BFH.
Well, dang....
Yeah, it's small, but still. Need to see what I can find to clean it up to prevent corrosion. No mark on the tire. I have never dinged a rim off-road without some mark on the tire.
Since it’s basically scrap metal now I’ll give you $5 shipped to Colorado!Well, dang....
Yeah, the first rim ding is the worst. You should have seen the rims on my Tundra. What a mess they were. I still find it odd that there is no mark on the tire.Since it’s basically scrap metal now I’ll give you $5 shipped to Colorado!
All jokes aside, first ones the worst. Just wear the trail damage as honor!
Time for Rock Warriors!Well, dang....
