Fellas, all alone here with a 3b with a knock.
earlier today i started her-up, as she ran as usual i added around 5 gallons of bio diesel (around 10 min.)
shut her off for 30 min. then out of the blue i'm getting this knock.
oil topped off ...
the night before i moved the sediment container from where it was attatched to,
to the fire wall.
i opened the top 10mm to see if i might have gotten some air. there was
some room for fuel so i topped that off.
thinking that i got air in the line i've been truying to bleed air post the sediment container.
well still knocking.
i didn't get to the back two injector to bleed, thinking of 't' ing off the fuel return.
but i'm not sure if air in the line is the cause of the knocking.
kinda scary and nerving.
she does smoke white some and should be still warm from warm up.(no smoke
when warm)
i noticed i had vacuum built-up when i opened the cap, but didn't run any different as i added the fuel in the tank.
question can i bleed air from the injectors like i would the brakes?
pump the fuel hand pump, hold it down and open the injector,
close then release the pump.
i feel like i'm wishing its just air in the line, ...
appreciate any input on diagnosing my situation if it would bee a
spun bearing or dropped pre-cup
thanks,
n8
oil topped off ...
to the fire wall.
when warm)
thanks,
n8
