oil pressure gauge
Discussion in '80-Series Tech' started by semlin, May 20, 2003.
  1. semlin
    semlin rocker
    5,208
    Media:
    1
    324
    Mar 27, 2003
    north of 49
    I’m just curious about what your oil pressure gauges indicate during normal operation. My owner’s manual says it should always be between the two lines. It is in town, but once it gets good and warm on the highway it will drop down below the bottom line by maybe 1/8" at idle (which is smooth)
  2. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    Semlin - mine used to act exactly the same way. Hmm, then I had my engine replaced - and now it's always in the middle. :eek: Keep in mind that the oil sending unit on these is a piece of dung.
  3. PHAEDRUS
    PHAEDRUS
    2,036
    Mar 31, 2003
    semlin,
    Mine is a 92, same thing halfway at start up and around town but on hte freeway it stays right around the lower line.
    Dave :beer:
  4. Desertmaster
    Desertmaster
    250
    Mar 28, 2003
    Semlin,
    I own a 97 model, at idel the gauge is always around the lower line either on it or a hair below it, on highway speeds (60-65miles/hour) stays around the 60% level just over the 1/2 mark by few nothches.
    Hope this helps.
    Thanks
    Al
  5. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    I guess 40's and 80's are pretty similar, my 40 does the same thing, its waay up at cold idle, and perfect at speed warm, but at warm idle its a little low. I first tried adding a quart of Lucas Oil Supplement, helped for awhile, today I changed to 20w-50 at mechanics recommendation, so far so good, seems to run a little better on the 20w 50 too.
  6. semlin
    semlin rocker
    5,208
    Media:
    1
    324
    Mar 27, 2003
    north of 49
    Junk, not sure if you are joking or not... what happened to kill your first motor anyway? &nbsp:Didn't you run through several shortblocks in a row?
    GA, hmm never thought about viscosity, you don't think running 5w30 mobil 1 might be causing low pressure with 130k on the clock?
  7. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    Yeah, in the 2-1/4 years that I've had my beater, I'm on my 3rd block. First one was the head gasket about 10 days after I bought it (thank goodness for certified used cars :D).
    My comment was not meant to be a joke. If you think it's funky, get a real gauge on it. Just my $0.0000003
  8. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    I doubt it's causing it, but its probably not helping much, my 40 either has ~90k or ~190k on the odo, we're not sure. So far the 20w 50 has definatly shown an improvement, you might want to try it at your next change, that or substitute of quart of Lucas Oil supplement for a quart of oil.
  9. yomama
    yomama
    291
    Mar 27, 2003
    Viscosity has allot to do with it, that is why at start up, thick oil, more pressure. When the engine reaches normal temp, oil is thinner, pressure drops. The 1/4 line at the bottom at normal temp and idle is fine, at highway speeds you should be up in the 3/4 range. I am running Amsoil and this is what I get.
    Yomama
  10. tiorio
    tiorio
    378
    Apr 11, 2003
    Re: oil pressure gauge (REALLY LONG)
    :::VERY LONG POST ALERT:::
    Viscosity is certainly a factor, as is the condition of the oiling system but keep in mind that high pressure does not mean that all is well! You could partially block a passage and get high pressure but be f-ing your engine post-haste!
    Cold oil is 'thicker' than warm oil which accounts for the main difference between the readings warm and and cold (the viscosity changes as temp changes). My manual has a few things to say about it all but basically it boils down to this:
    Cold idle - gauge can be in between the two white marks
    Warm idle - gauge can be between the bottom and the lower mark.
    Cold running - the important part here is that the gauge doesn't show oil pressure too high, can be inbetween the higher mark and the top.
    Warm running - the gauge can be in between the two middle marks.
    (I'll try to remember to look at the manual tonight to see what the real verbage is)
    Anyway, there are two important things going on and pressure is only one of them. Flow is very important as you want as fresh a supply of oil as possible getting to the friction surfaces. So if you put in 90w gear oil, you'll have great pressure but the oil will be sitting on the friction surfaces for waaaaay too long, burning up and breaking down and leaving crud...bad!
    If you use oil with too low a viscosity (too thin) it will squirt out the biggest 'holes' and pressure will drop to the rest of the system. This leaves some friction surfaces with insufficent oil supply...also bad!
    So like most things in the automotive world, it's a balance. As we don't have oil flow gauges in our rigs we rely on pressure readings. In the case of automotive engines/gauges, we also need the manufacturer to tell us what pressure relates to proper flow. When the pressure gauge reads within manufacturers specs., we have to assume flow is ok as well as long as (and this is important) everything else in the lubrication system in clean and operating correctly. We already said that a blockage can give us artificially high readings (well, the readings are accurate technically but the relationship to flow has been thrown out the window by the blockage).
    Because oil viscosity is a fairly level standard on which to base the calculations and as most automotive engines use said oil as their primary source of lubrication there is a pretty acceptable range of pressures for general automotive use, but even if you do have a numeric gauge installed you are working with generalizations about how the pressure relates to flow (unless the FSM has actual pressure information, which it certainly may!).
    Anyway, if you're still awake (again after the airbag diatribe)...
    The net result is that oil pressure in the context of factory specs. gives you some important information about the health of your lubrication system. With the correct viscosity oil at the correct temp. your gauge should read within factory specs. (assuming the gauge and sender are working correctly, ALWAYS CHECK THIS FIRST before assuming you have an oiling problem!)
    If the gauge reads higher than it should, you most likely have a blockage or colluded passages (crud build-up in the oil passages making a smaller orifice for oil to get through), or even a blocked filter/filter bypass.
    If the gauge reads lower than it should, you either have a blocked or colluded passage on the INTAKE side of the pump (scanvenge side, something blocking the pickup [gasket material anyone?]) or you have 'bigger' openings or clearances between friction surfaces or a bona-fide leak in the internal lubrication system. The most common on our higher-mileage engines is that normal wear has enlargened the clearances on moving parts and more oil is escaping in various areas. This means higher flow to these higher wear parts (good) but less flow to the other areas of the engine (uhh, that would be BAD).
    The trick on an engine with this type of wear is to restore the balance. If we want the correct flow, and we have to determine flow with pressure, we strive for the correct pressure. We want the gauges to be where they should, right?
    Here's where personal preference comes into play. As my cars get older and the pressure drops from wear, I use a higher viscosity oil. When my LC hit 100k and the pressure was a bit lower than it was at say 30k when I bought it I started to add 10w-30 and 10w-40 mix to bring the pressure closer to spec. What does that do? It REDUCES the acual flow of oil through the system(!), but it allows the areas that would not be getting as much oil as they would with thinner oil to be properly lubricated. That is my preference for managing wear in my engine.
    The net result is this: as an engine wears, it does so exponentially. The more wear in your motor, the more loose the clearances, the worse the lubrication system works as the pressure/flow begin to deviate and drop. Most manufacturers account for this in their designs but you can't change physics! The engine that is seriously over-lubed to begin with will have a longer life (as it pertains to pressure lubricated friction surfaces eg: not piston rings etc.). A prime example is the well maintained Porsche 911 which has a serious oiling system as it's basically oil cooled. If the engine is maintained it generally will go over 150k miles, and even then the bottom end is usually intact! This isn't necessarily fantastic when compared to 'regular' cars but in the land of 'real' sports cars it's unheard of (compared to Ferrari, Lambo, etc.)...
    However, should my oil pressure drop enough to start requiring 50w or higher, I would seriously think about rebuilding. Compensating for lower pressure with higher viscosity oil is managing the demise of your engine, not fixing the flow problem. The longer this goes on, the lower the more accelerated the wear, the lower the pressure, the less efficient the lubrication system, the higher the clearance until something breaks. Here's where it gets ugly:
    If your oil pressure is getting really low and you decide to rebuild, you decide the following:
    Time
    Place
    Components to be replaced (to an extent)
    Cost (based on the above, again to an extent)
    If you try to compensate for too long, something will self-destruct, usually in spectacular fashion taking out A LOT of very expensive parts with it (remember, were talking about the pressure lubrication system here). Something like a rod or crankshaft at 3000RPM... while you're 100 miles from anywhere... on your way to an important work meeting... with the only local garage being a Jeep shop... that doesn't take credit cards... in a town with no hotel... You get the idea. You don't get to manage much at all!
    As your motor runs towards it's inevitable demise, it does so faster the longer it goes. Not to say the LC bottom end won't go 650k or longer, but eventually it will die and the longer it goes, the sooner it will happen (well DUH!).
    Ok, enough already. Having said all that, I drove my 40 knowingly as long as it would go. But I had a backup vehicle and didn't stray too far from home with it. It threw a rod right through the case and took out the top end with it. Spectacular destruction! But I had to have a tow, was very late to a wedding, and havent' had the cash or time to fix it yet. If I depended on it I would have rebuilt when I knew things were heading downhill based on a number of factors, the most important being oil pressure.
    Wow, and I could have probably just said 'adding higher viscosity oil doesn't really solve the solve the problem of low oil pressure, it just helps manage the flow changes due to wear'...
    But I didnt! :-X :-X :-X
  11. tiorio
    tiorio
    378
    Apr 11, 2003
    Uhh, one more thing. Although I yammer on about the pressure/flow thing the other part that isn't mentioned is the lubrication characteristics of different viscosity oils. Not a major factor here between 10w30 and 10w50 but something worth a mention...
    I'm seriously done now, promise...
  12. Photoman
    Photoman SILVER Star
    1,145
    Media:
    41
    47
    Mar 28, 2003
    One other consideration to the oil pressure viscosity thing is the ambient temperature. In cold weather climates choosing the proper viscosity is important to get your buggy to turn over in the AM. Oil pressure will be especially high with the thicker oil at this time.
    Running thicker oil in an older motor like CruisinGa was talking about can increase the power by improving compression. - less clearance around the rings. Just don't do like the old, old timers used to do - fill it with 90 weight and sawdust and sell it. :slap:
    Bill
  13. Hltoppr
    Hltoppr SILVER Star
    2,024
    Media:
    4
    5
    Aug 29, 2002
    Port of Indecision...otherwise Northern Arizona
    Hey Bill,
    Off topic, but I've been curious about the chain link fence thingy attached to your Bullbar in your Alaska trip pics. Care to fill me in on what this is for?
    Gracias,
    -H-
  14. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    .... oh and here's from the second engine :tear:
    [​IMG]
  15. Hltoppr
    Hltoppr SILVER Star
    2,024
    Media:
    4
    5
    Aug 29, 2002
  16. Photoman
    1,145
    Media:
    41
    47
    Mar 28, 2003
    -H-,
    Check out the Checking Air Bag Status question at the bottom of this page where I posted an answer to your question and send check to photoman@paypal for the latest model.
    Bill
  17. semlin
    semlin rocker
    5,208
    Media:
    1
    324
    Mar 27, 2003
    north of 49
    um, so do people think I've got a problem that needs looking at if my pressure when very warm is 1/8" below the mid-line at idle? I never go over the top line and only go below the mid-line at idle after sustained highway driving. I just changed the oil 10 days ago at mobil 1 prices so I'm hesitating about going to 10w30. However, I would rather spend the $ than buy a shortblock.
  18. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    Isn't it possible for the gears in the gear drivin oil pumps LC's have to wear, causing them to pump less flow and pressure? In my haynes it has something do do with checking gear backlash on oil pump gears, and SOR carries just the gears to rebuild an old pump. So couldn't technically the pump be wearing as well, thus contributing to the oil flow/deterioration curve, and if rebuilt, will help it somewhat by providing the same flow and pressure as when new, despite more of it being lost due to worn parts etc?
  19. Photoman
    1,145
    Media:
    41
    47
    Mar 28, 2003
    CruisinGa,
    Yes, your right. Anytime I rebuild an engine I ALWAYS replace the oil pump. That being said, usually by the time the oil pump is worn the engine needs rebuilt anyway. There are exceptions. Many times the gear kits come with a new flat plate as it will have gear marks worn in it also. Just FWIW in the old days when I used to race I would stretch the relief spring or put a washer under it so the pump would put out more pressure.
    Bill
