Oil Pan Leak Update (2 Viewers)
North Front Range, CO
I temporarily. solved the oil pan to oil pump seal leak. I tightened the oil pan bolts. It has been almost 2000mi and the oil leval has not moved. Not bad for 218k mi. I just started Mobil 1 oil last fall.
How many mile on oil change with Mobil 1?
kurt
Personally I go 5,000 between oil/filter changes. It's easy on the scheduling.
Rick
Is this with mobil 1 also? What would you recommend for conventional oil?
I see Amsoil has a 7500 mi oil. Wounder if it is the same as the regular Amsoil?
kurt
