Oil Pan Leak Update
Discussion in '80-Series Tech' started by landtoy80, Apr 9, 2003.
  1. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    North Front Range, CO
    I temporarily. solved the oil pan to oil pump seal leak. I tightened the oil pan bolts. It has been almost 2000mi and the oil leval has not moved. Not bad for 218k mi. I just started Mobil 1 oil last fall.
    How many mile on oil change with Mobil 1?
    kurt
  2. landtank
    landtank SILVER Star
    18,422
    595
    Mar 27, 2003
    Groveland MA
    Personally I go 5,000 between oil/filter changes. It's easy on the scheduling.
    Rick
  3. Wrench
    Wrench One Bashed Up 80
    4,491
    176
    Mar 27, 2003
    Is this with mobil 1 also? What would you recommend for conventional oil?
  4. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    I see Amsoil has a 7500 mi oil. Wounder if it is the same as the regular Amsoil?
    kurt
  5. landtank
    18,422
    595
    Mar 27, 2003
    Groveland MA
    Yes that is with Mobil 1 as well. It's a little over kill for a synthetic but as I said it's easy on the scheduling and if I can't get to it right at 5k I figure I have a little time still.
    Rick
