I've been a lurker for a while but happy to introduce our FJ40. I've got a 98 LX470 with 330k miles that's been my daily driver since about 2002. I had been looking for an FJ40 for a while now and finally came across one that I think it a good starting point. It's a 77 with 82k miles. The good is that the body and frame are mostly rust free (just a little surface rust here and there at paint chips). The bad is that the floor pans have some rust and have been patched in the driver and passenger foot wells. Not terrible for a 40 year old car. Two owners ago (I believe) a Chevy 350 was swapped into it with factory 4 speed and t case. The roll bar was removed to fit the longer jump seats. I plan on putting the roll bar back in and using the SOR adapters to make the long jump seats work.
The first project on hand is putting in power steering. I've searched and read through countless threads. I'm thinking I'll use the saginaw pump with an FJ60 box. I couldn't see where anybody confirmed that the FJ60 box is a direct bolt in. Any help there would be great. It has 31" tires and I plan on leaving it like that. It's going to be an around town / beach cruiser in St. Pete, FL so I won't need anything over the top for oversized tires, etc...
Also, when I first test drove it, the car had side pipes and no mufflers. I had the exhaust redone and now I can hear a high pitched whine that was masked by the loud exhaust. The noise increases with RPM's and doesn't change if clutch is pressed or not. I've already pulled the belt to confirm it's not the alternator. Any ideas / any common problem that may be causing this? It sounds like it may be coming from trans / clutch area.
Looking forward to hearing what you guys think. Open to any other ideas / input you guys might have. Here are a couple of pics, including the day I picked it up.
