HI
Does anyone know what the actual recommended Axles weights are from Toyota?
I have been looking through this forum and other forums in France and Spain, looked in my FJ and BJ Manuals but can not find these numbers anywhere.
I live in Spain and have done some modifications to my BJ40. Here the paperwork is a nightmare. You have to have an engineers report on the modifications, with technical specs and invoices supplied. The final part of this process is to have the vehicle weighed.
I took it to a testing centre and they weighed the front axle, the back axle and the whole vehicle.
When they compared them to the original weights it seemed a bit crazy. Bear in mind I have added the same wheels and tyres front and back (ie same weight) and same suspension.
The front weight as originally stated was. 895kg it is now 1035kg
The back weight as originally stated was 1281kg and is now 855kg
Because of this, I can not get the paperwork accepted as the difference on the front axle is too high. The BJ had its factory fitted PTO winch both times (I am assuming) as I do not know for sure for the original tests.
Any information on the Toyota original axle weights would be greatly appreciated and a copy of any documentation would be even better
Many thanks
Jules
Many thanks
Jules
