Leaking intake
Discussion in '40- & 55-Series Tech' started by green40, Aug 31, 2003.
  1. green40
    green40
    3,417
    82
    Apr 16, 2003
    Swanzey NH
    What would the symptoms be if my intake wasn't totally sealed? I replaced a broken exhaust manifold and have not been able to get the engine to run since then. I figure that there are 2 reasons it's not running, either the manifold is allow air to leak in or when I pulled the carb (just laid it on it's side on the valve cover) some gunk loosened up and clogged something. Right now it will start if I pump it 5 or 6 times, then give it full throtle once it fires. It will not idle. It's a 74 F engine. Thanks :'( Lane
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,605
    2,983
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    You could easily have a vacuum leak. I assume you used new gaskets when you put it back togther? Do you have a vacuum gauge? There is an old trick to check for leaks. It requires that you spray the area where the manifold attaches to the head with carb spray and see if the engine smooths out or runs differently. That can be a dangerous thing to do with a hot motor. spray penetrating oil or some such other stuff would probably work and be less flamable.
    Paging Gumby......What say ye Gummer.
  3. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    Sounds like you don't have power to your fuel cutoff solenoid.
  4. green40
    green40
    3,417
    82
    Apr 16, 2003
    Swanzey NH
    Re:Leaking intake/ update
    :D pulled the manifolds off and doubled them up (used the old one, and a sealer) started right up and ran fine! Thanks for everyones ideas! :D
    Lane
