John Deere LA110 Lawn Tractor
Discussion in 'Tractors' started by Gold Boy, May 26, 2007.
  1. Gold Boy
    Gold Boy
    2,087
    2
    Aug 5, 2005
    Southern Interior, BC, Canada.
    is there a better lawn tractor for the same price or less?
    thanks and :beer:
  2. Radd Cruisers
    Radd Cruisers
    7,932
    68
    Sep 28, 2002
    Vancouver Island BC Canada
    My mom just purchased one from Sears that was comparable and even rated very well in consumers reports for less money.
  3. Dave-T
    Dave-T
    1,546
    1
    Oct 30, 2006
    Heber City, UT
    How much is that JD? Kubota makes some pretty cool ones.
    I've been very happy with Craftsman mowers. I got one with a Kholer engine.
  4. Dave-T
    Dave-T
    1,546
    1
    Oct 30, 2006
    Heber City, UT
    The right mower also depends on your application. If you are mowing a lot of manicured grass, look into a zturn.
  5. Gold Boy
    Gold Boy
    2,087
    2
    Aug 5, 2005
    $2079.00 CAN - not a bad price for a JD
    :D
  6. Dave-T
    Dave-T
    1,546
    1
    Oct 30, 2006
    Heber City, UT
    Sounds like a deal to me. What engine is in it? Is it hydrostatic drive?
    As far as the cutting deck is concerned I much more prefer 2 big blades over 3 smaller.
  7. nicholastheczar
    nicholastheczar
    1,414
    4
    Aug 23, 2005
    The Woodlands, TX
    I just bought a Cub Cadet 1045 w/ 46" deck and hydrostatic transmission and am very happy with it. I did a bunch of research on different models before I bought and all the reviews I read as well as the quality of the mower lead me to the Cub Cadet. I paid $1699 at my local TSC.
  8. Gold Boy
    Gold Boy
    2,087
    2
    Aug 5, 2005
    Power
    Exclusive 19.5-hp John Deere Anti-Vibration System (AVS) single-cylinder engine (manufactured by Briggs & Stratton) has plenty of power and torque to handle tough mulching, mowing, and bagging conditions
    Electronic ignition for fast starts
    Cast-iron sleeve for long engine life
    Overhead valves for excellent power and fuel economy
    No-tools oil drain valve provides easy access for oil changes
    Full-pressure lubrication and oil filter keep oil cleaner for long engine life and extends time between oil changes
    Durability
    Solid one-piece frame is constructed of 12-gauge steel
    Full-length robotically welded frame design has high-strength steel rails for added strength and long life
    One-piece fender deck is bolted to the frame
    Performance
    Two-pedal automatic transmission for easy speed and direction changes
    42-inch (2-blade) mower deck featuring The Edge™ Cutting System provides superior grass lift for a precise, level cut
    Optional Mulch cover and Bagger
    Starlock blade design keeps the blade bolt at the correct torque for easy removal
    Convenience
    Exclusive CargO Mount™ System allows for quick hookup of front and rear attachments and accessories
    Focused reflector headlights light up work area, dusk to dawn
    Low-effort 14-position mowing height adjuster features cutting-height reminder
    Fuel sight gauge lets you check fuel levels at a glance
    Comfort
    Three-spoke steering wheel for greater operator comfort and control
    Ignition switch is on the dash for starting ease
    Wide footrest areas with non-slip, anti-vibration rubber footpads are provided for operator comfort and safety
    Comfortable, padded seat can be easily adjusted forward or rearward while in the seat, with seat travel of 5-1/2-inches and 10 different positions
    Seat can be tilted forward for protection from the elements and to provide easy access to the fuel tank
    Cup holder cradles your favorite beverage
    Step-through design makes it easy to get on and off tractor; provides more leg room
    List Price: $1,649.00* (U.S.)
    well i got one today, so thanks for all your feed back.
    :):):):beer:
    edit - wife says i can't have an arb bumper now. :crybaby:
  9. Eric Winkworth
    Eric Winkworth
    2,069
    1
    Mar 1, 2005
    Stay away from kubota...
    The JD's with Kawasaki engines rock, the B&S engines are okay, but just don't last... The older cast iron Kolhors are amazing, gutless as heck but tanks... kind of like Landcruisers :)
    I've herd good things about huskavarna and a few other cheaper brands....
    to me if you can find an older JD that doesn't use oil and you keep up on the little maintance it will last!!!! a long long time....
    there were years I know my dad didn't change the oil in our 210 cast iron kohlor (I think almost half a decade the one time) it has cost use 200 bucks in 20 years of owning it... one reman'd starter, a battery (actually two but one was out of a wreck car) oil for engine and axle... and a few belts.... I've never even looked at the points and the thing was built in early to mid 70's... I can't say enough for the old girl....
    A good buddy of my dads has a Kubota that cost over 13000 CDN and has been in and out of the shop since new 2 years ago, with everything from replace hydrostatic to wheels falling off... it's a crazy liquid cooled engine... after talking to him I wouldn't touch one with a 10 foot pole...
    cheers
    Eric
  10. Gold Boy
    Gold Boy
    2,087
    2
    Aug 5, 2005
    no problems and she still runs like new.
