So, I picked up a '97 with ~170,000 miles on the 29th of July and have driven nearly 3,000 trouble-free miles since. My full tank mileages have ranged from 13.1mpg to 16.1mpg, idle is around 600RPM, and the engine seems to have decent power and runs well.
In the last week I now seem to have begun seeing intermittent starting issues when the vehicle is hot.
I've had this problem twice, both times when trying to start the Cruiser in the late afternoon on 90+ degree days after having driven it on a number of trips of 5-20 minutes in the morning and early afternoon. I've attempted to reproduce this issue since the first time and was not successful until today (though, I wasn't actually trying today).
First occurrence (8/9/11 - 81* high, parked in sun):
Second occurrence (8/13/11 - 89* high, parked in sun):
So, I'm a bit stumped.
The first situation took me by surprise with little in the way of tools with me, so is not a source of much information.
The second situation simply confused me more - no spark was apparent, but start was eventually successful. This start occurred before I could test for fuel and I saw no spark (though this may mean nothing), so no real information there (at least as far as I can tell).
Given the information above, does any one have any clue as to where I should be looking next? I don't want to completely shotgun this, replacing things without reason, but am really not sure where to look next as I can't necessarily reproduce the issue on demand. Any help would be much appreciated...
- Parked Cruiser at ~4:15, tried to start at ~5:00. Turns over strongly, but does not start.
- Left alone for ~1 hour to search MUD and to run an errand
- Checked codes -> no codes or pending codes
- Checked fuses in driver's footwell and underhood -> no apparent issues
- Checked relays underhood -> no apparent issues
- Attempted start -> start OK
- Parked Cruiser at ~3:30, tried to start at ~4:40. Turns over strongly, but does not start.
- Put in different EFI relay (guessing as relay seems to be especially hot) -> no start
- Ran inside an pulled up "Emergency Start Troubleshooting procedures" from the FAQ -> started working through "Scenario 3"
- Check engine light is burned out, so is not visible one way or the other
- Pulled #1 spark plug, attempted start while holding spark plug against block -> no spark observed, no start
- Re-installed #1 spark plug and attempted start while listening for fuel pump -> no start and no fuel pump heard
- On a whim, pulled #1 spark plug and tested again with no apparent spark @ ~5:15-> start OK
- Shut down, re-installed #1 plug and associated wiring
- Attempt start @ 5:20 -> start ok
