Hi guys, it's been a while.
I am researching a new project - to build a dual purpose tandem off-road expedition trailer.
I am trying to figure out which suspension to buy?.
Saw this on a caravan online:-
and found this kit / system on ebay.
at this link:-
[URL]http://www.ebay.com.au/itm/OFF-ROAD-CAMPER-TRAILER-CARAVAN-INDEPENDENT-SUSPENSION-/170622875206?pt=AU_product_Trailer_Parts&hash=item27b9ea7646
[/URL]
So I am looking to do a dual purpose tandem hydraulic tipping trailer along these lines.
Planning to make a slide in camper unit with roof top tent, for weekend expeditions / camping, so that the trailer can be used for gathering firewood in the forest, or with the expedition camper unit - be rtaken out camping for holidays weekends.
However,
I am not real keen on the leaf springs and full length square axles due to lack of ground clearance offroad.
This "cruisemaster" is one product available down under that MIGHT be suitable maybe.
or another option is this one:-
I've built a few trailers before today - but never an off road 'expedition' nor a 'hydraulic tipper' much less one that will do both!.
I've been building a few of these VMS signage trailers of late but they just have leaf springs & square full length axles, so this independent off road suspension is all new to me - and I am very happy to hear any and all advice about good designs or good manufacturers to deal with.
Basically the reason I would like to get away from leaf springs and full length axles is that with our mostly sandy terrain, most off road tracks here have deep wheel ruts in soft sand, with a large sandy hump of sand in the middle of the track and normal trailers with solid square axles - tend to "plow" the center hump as you tow them offroad, which wants to bend the full length axles backwards and upwards destroying tow in and camber etc (not to mention dragging the towing vehicle to a stop).
Using an "off road trailer" with tall deck height, is a bear, when loading the hardwood because you have to lift every piece high up off the ground to get them into the trailer. Similarly when camping - you don't want to fall 4 or more feet to the ground out of the camper in the middle of the night when your getting out to answer the call of nature etc. If you happen to be loading "rings" of hardwood firewood, then these are even heavier, to lift any distance off the ground... the lower the trailer is to the ground the better, some rings it's better to roll them up a ramp into the trailer so again low height is a decided bonus.
Then to get back OUT of these spots, it's better if the trailer is "taller" and has greater ground clearance.
So a trailer that has air operated independent suspension, can have greater ground clearance in the middle for off road towing, but isn't always ideal when you get to where your going for camping or fire wood gathering - in which case you can air it down once there.
My plan with "air independent suspension" is to have the best of both worlds - the ability to air the trailer up for towing / access into and out of remote spots, but the ability to air it down when actually camping and loading firewood... air it up to tow it home then 'tip' the load off once at home.
Thus my interest in this "new to me" air independent suspension caper - that I have never encountered before.
It will be a GVM (Gross Vehicle Mass) of 3000kilos (~6600 lbs) because one of the vehicles that will tow it is:-
Which can only tow 3000 kilo max. (My own F 250 will pull 4250kilo with no trouble - so that's the 'recovery truck' if anything goes wrong).
Anyone with experience in this area of off road / expedition trailer construction, care to advise what brand of suspension to buy and who to purchase it from?
Many thanks in advance guys.
at this link:-
[/URL]
However,
