hybrid D60 axles
Discussion in '40- & 55-Series Tech' started by preacherman, Aug 11, 2003.
  1. preacherman
    preacherman
    235
    Oct 1, 2002
    Midland Texas
    Anyone ever heard of cutting your nuckles off of a toyota front axle and welding dana 60 nuckles on? I realize you would have to get custom axle shafts and have to change the front rims, but is it possible? What about dana 44 knuckles? It seems like you could use all of the d60 outer parts (hub, brakes, etc.) and have a way strong axle.
  2. woody
    woody Internet Fireman Staff Member
    10,336
    Media:
    303
    1,097
    Jan 15, 2002
    Toquerville UT
  3. hendo
    hendo
    181
    Sep 10, 2003
    san fernando valley
    i asked currie if they could do it but they wanted the third member side gear for them to tell me if they could do it or not,all pro do it for about 5k sunray do a ford9"d60 outer for about5.5k
  4. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
  5. Medusa
    Medusa
    416
    1
    Jun 17, 2002
    As noted, AllPro has been doing this for several years. IMO it is a lot of work and/or $$ for the benefit. With the hybrid, you get stonger shafts and outers, but are still stuck with the limitations of the Toyota third member, including 30-spline side gears (and hence axle shafts) and very limited range of lower R&P gears. I would recommend a complete 35-spline (inner and outer) D60 narrowed to your specifications.
  6. gkhal1
    gkhal1
    52
    Apr 17, 2003
    I agree with Medusa's approach. Find some cheap used and build to your specs. Make sure you go with kingpin D60, not earlier type.
  7. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,021
    Media:
    17
    266
    Oct 1, 2003
    MN
    I like my Dana 60's. They have worked great for me. They are not for everyone,for many reasons. Further, there are products out there that seem to be working for others very well, smurf,long,etc. But, they are not for me, in my application. I do not want to have to even think about breaking a birfield, or an inner or ???
    I did not want to go hybrid, and would not now. The only thing that I would consider changing is going to a ProRock center from Dynatrac for my 60's. I am going to be building a set of 60's for an 80 project that I have going on and will be using those center sections. Should be a funtime!
  8. joe cabela
    joe cabela
    57
    Oct 7, 2003
    [quote author=Medusa link=board=1;threadid=4265;start=msg41754#msg41754 date=1063726141]
    [/quote]
    Well said. My 60's are getting worked over as we speak.
  9. Poser
    20,021
    Media:
    17
    266
    Oct 1, 2003
    MN
    [quote
    Are you making them yourself, or having a shop make them, and if so, how much?
    How are they going to be configured? (bolt pattern, brake set up, lockers, etc)
  10. joe cabela
    joe cabela
    57
    Oct 7, 2003
    Actuall it is a 60 front and a shaved 70 on the rear. I am having a shop narrow them down. Im staying 8 lug with oem disc in the front, rear disc from Blackbirds custom trucks. Cro mo shafts from dutchman 1.5 x 35 spline all the way through. CTM joints 4.88 R and P with arb's front and rear. OTT high steer arms
    I need a :beer: (out of breath)
    Cost? Cost? you cant be concerned with that and if I actually bring myself to say it I probably will cry (did I mention that Im also installing an Atlas)
    Lets just say alot but you cant take it with you.
    The labor to narrow them is not bad its the Bling Bling parts that kill you.
  11. HI^C
    HI^C
    1,234
    2
    May 22, 2003
    just curious why spend all that money on the axles, then buy a $1000+ bombshell and have it as your weak point?
  12. joe cabela
    joe cabela
    57
    Oct 7, 2003
    Not sure what bombshell you are refering to?? ???
  13. Poser
    20,021
    Media:
    17
    266
    Oct 1, 2003
    MN
    [quote author=HI^C link=board=1;threadid=4265;start=msg52185#msg52185 date=1066442330]
    [/quote]
    What is weak in this set up?
