- Thread starter
- #21
Ok- I've rebuilt my intake and exhaust manifolds. Here's what I've done:
1. Had the cracked aluminum intake welded.
2. Replaced the wavy washers in the swivel ends of the exhaust manifold to try to prevent leaks.
3. Installed SOR Stainless block off plate and trimmed the flapper valve to fit and operate properly. I tested it with a torch to make sure it was working.
4. Painted the intake with POR 15 high temp aluminum paint.
5. Painted the exhaust manifold with POR15 high temp grey manifold paint.
6. Installed new bolts and torqued everything down.
7. Had the surfaces machined to ensure straight edge.
Here's my problem:
I don't know if I should go through the trouble of swapping this one in. I have new Remflex gaskets RTG.
The reason I wanted to do this is I suspect a cracked intake on mine. My vacuum at idle runs around 17-18 and the cruiser is running very good, but when I set the timing to factory 7 deg (on the BB), I get pinging easily. When I retard the timing (1/2 way between TDC (the line) and the BB, I get backfire.
I have rebuilt the carb and gone through the emissions stuff. The only other thing I know that is not right is the OC sensor is not functioning properly (no resistance on my Ohm meter).
I might be able to desmog my rig in 1-2 years, so I would probably go with a header then. I have to wait until it is 24 years old in Texas, though to pass inspection. I do not have to smog test in my county, but all the other smog equip is in place.
Any thoughts?
Here's my problem:
Any thoughts?
