How to repair a cracked Intake Manifold
Discussion in '60-Series Wagons' started by hank14, Jun 10, 2009.
  1. hank14
    hank14 SILVER Star
    2,320
    18
    Nov 26, 2004
    Texas
    I bought a used stock intake and exhaust manifold, only to find a 3 inch hairline crack in the intake manifold where the isolator plate goes.
    Can this be repaired properly to prevent future cracking? I know the SOR.com stainless steel insulator is designed to prevent future cracking.
    I did not find any forum info here about repairing a cracked intake.
  2. Southeast Overland
    Southeast Overland Supporting Vendor
    9,302
    55
    Dec 1, 2006
    SC
    I'm not sure about the intakes but some have welded the exhaust manifolds.
    I have an extra intake manifold if you want it - PM me.
  3. Stumpalama
    Stumpalama Forum Junkie SILVER Star
    4,851
    572
    Nov 5, 2004
    NOVA
    I had my intake welded about 10 years ago and it is still good. Find a good aluminum welder and they can do it while ensuring the manifold doesn't warp.
    Also, you have to remove the likely culprit: the thermo nuclear reactor, or the exhaust diverter thingy. They invariable fail in the up position directing the hot exhaust directly on to the manifild below the carb.
  4. GLTHFJ60
    GLTHFJ60 Rum Runnin' SILVER Star
    17,481
    1,552
    Apr 18, 2005
    Durham, NC
    Definitely a good thing to point out. I have a hairline crack as well, but I ignored it. I probably should have had it repaired / replaced, eh?
  5. Cruzerman
    Cruzerman
    1,556
    95
    Apr 23, 2005
    Oregon
    I had a crack in my intake on my 40. Took it to a good aluminum welder and he stiched it right up.
  6. zuluzeugma
    zuluzeugma SILVER Star
    1,695
    2
    Sep 11, 2002
    Midland, TX
    I have one for sale if you want to go that route.
  7. Stumpalama
    4,851
    572
    Nov 5, 2004
    NOVA
    Yeah, that little crack caused me all sorts of frustration when trying to chase down a vacuum leak. the truck would alternate between exhibiting signs of running rich, then running lean.
    Also, if the intake is cracked, have the mounting face (against the head) checked for true.
    If it needs to be milled, I recommend having the machine shop mill the intake and exhaust as one unit, that way they are sure to fit tight on the head.
  8. GLTHFJ60
    17,481
    1,552
    Apr 18, 2005
    Durham, NC
    Damn. I gotta go back in there and pull it off I guess.
  9. NLXTACY
    NLXTACY Wits' End Supporting Vendor
    17,386
    5,335
    Dec 7, 2007
    West Hills, CA
    If you guys are noticing cracks in the intake, like I had, make sure your carb fan is working properly.
  10. GLTHFJ60
    17,481
    1,552
    Apr 18, 2005
    Durham, NC
    Did that about a month ago, or whenever you posted up that easy solution, and just got installing my Remflex on Sunday. At least I think I can get the manifold off without taking the header all the way out.
  11. NLXTACY
    17,386
    5,335
    Dec 7, 2007
    West Hills, CA
    yeah if you have the bolts and not the studs then its actually pretty easy, relatively :D
  12. GLTHFJ60
    17,481
    1,552
    Apr 18, 2005
    Durham, NC
    Were there ever two options? I thought the stock config was two studs top + center with the rest as bolts.
  13. NLXTACY
    17,386
    5,335
    Dec 7, 2007
    West Hills, CA
    The option is an aftermarket option. I originally went with studs because its supposed to be easier to get the manifold back onto the head because you aren't sitting there trying to align it, holding it up, trying to thread in a starter bolt. In retrospect its a PAIN IN THE ASS to use studs with the engine still IN the truck :bang:
  14. GLTHFJ60
    17,481
    1,552
    Apr 18, 2005
    Durham, NC
    With only the two top studs? I could think of no other way for installing headers. It would be impossible to install headers with one person without the studs.
    Think JB weld would hold the crack?
  15. NLXTACY
    17,386
    5,335
    Dec 7, 2007
    West Hills, CA
    To be honest, yes I do. Or try FastSteel. I was gonna try it if Mark A. didn't have a good one.
  16. GLTHFJ60
    17,481
    1,552
    Apr 18, 2005
    Durham, NC
    The last thing I'd want is to have that JB weld get sucked into my motor. What if I sealed the crack from the bottom of the manifold? I could definitely get away without taking the whole shebang off :hmm:
  17. hank14
    hank14 SILVER Star
    2,320
    18
    Nov 26, 2004
    Texas
    Thanks for the offers on the other intakes. I don't think my original one has a crack, but one I bought to replace it does.
    I replaced the intake and exhaust manifold gasket and rebuilt the carb 6 months ago. New SS J-tube fixed that pesky leak, but I didn't replace the gaskets or insulator between the intake and exhaust and I didn't replace the gasket/washers on the swivel ends of the exhaust manifold. I'm getting some very minor leaking from all 3 of those. So, I wanted to rebuild the replacement intake and exhaust manifolds and swap them out for my original ones. I don't want to have to do it again.
    Now, I'm tempted to go new OEM, or get a header to avoid all this mess.
    I also have some minor backfiring when I first get out on the road- letting off the gas to shift gears- when the engine is cool and the choke is off. I don't know if that's related to the intake/exhaust or my homebrew carb rebuild.
  18. Stumpalama
    4,851
    572
    Nov 5, 2004
    NOVA
    Indicates a rich mixture... but better a little rich than too lean. If you don't have one, go out and get a vacuum gauge (they're cheap) from autozone/sears. Hook it up to your brake booster line after you've got your engine up to operating temp. It and a timing light will tell you and amazing amount about the running condition of your engine. There is a great write-up in the tech section about using a timing light and a vacuum gauge to tune your rig properly. I swear by it... I averaged 14.65 MPG at an average speed of 70MPH (by GPS) with 2F, smogged, headers, 4.11 gears, 4spd and 35" BFG MT's on a recent trip to Hilton Head.
  19. Michael Hanson
    Michael Hanson
    7,490
    7
    Oct 30, 2007
    Plano texas
    If its aluminum,clean and weld it.It will be fine. Mike
  20. hank14
    hank14 SILVER Star
    2,320
    18
    Nov 26, 2004
    Texas
    Good info. I have checked the vacuum. When the timing's set per the FSM, I get some pinging under load, so I have adjusted it to prevent that (not as advanced).
    I think I'll have someone weld the aluminum intake as suggested.:cheers:
