how much actual oil press...
Discussion in '80-Series Tech' started by instigator, Sep 5, 2003.
  1. instigator
    instigator
    255
    Nov 27, 2002
    georgia
    is normal for our trucks? i just put in a small mech guage and the thing was reading 98 psi at cold start up 40 psi at idle warm and over 100 psi at 3000 warm ? do these no.s sound right to you guys?
    yeh,did the search thing.
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,603
    2,981
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    sounds a bit high to me, where are you picking it up?
  3. cary
    cary
    3,109
    21
    May 7, 2003
    Cool, were finally getting some data. Instagator, can you tell us where on your gauge the various oil pressure correspond to? Thanks
    Cary
  4. instigator
    instigator
    255
    Nov 27, 2002
    georgia
    ok i installed the gauge at the filter via a sandwich adapter(oil cooler adpater flex-a-lite) this is to run a bypass oil filter (you know the one every one should install :D) but anyway. i'm not sure if i understand what you mean Cary please elaberate. the sandwich adapter is doing good no leaks but the filter assy is another story (maybe cause of the hight press. (the whole for my inquery)
    i'll post a pic of the install tonight when i get home from work. but i have the outlet of the adapter tee'd off for the gauge. and that where the press. is taken from.
    the pressure seems kinda high to me , maybe the gauge is erronious, also the gauge in the car reads normal but i resally dont know if that is accurate.i'll try to get more data as the project progresses
  5. instigator
    instigator
    255
    Nov 27, 2002
    georgia
    here is a pic of where the gauge is located
  6. instigator
    instigator
    255
    Nov 27, 2002
    georgia
    this the pressure gauge at a cold/warm condition at idle
  7. instigator
    instigator
    255
    Nov 27, 2002
    georgia
    this is a pic of the gauge at 2k-3k at cold/warm codition
  8. instigator
    instigator
    255
    Nov 27, 2002
    georgia
    heres a view of the installed unit
  9. instigator
    instigator
    255
    Nov 27, 2002
    georgia
    does no one here know what the actual oil press is supposed to be ? ???
  10. drexx
    drexx
    540
    4
    Sep 8, 2003
    10Sep2003 (UTC -7)
    From the factory manual, the 1FZ-FE should have 4.3+ psi at idle, and 36 to 71psi at 3,000rpm. The oil pressure is checked by removing the oil pressure switch and checking from there.
    For reference, the 2UZ-FE oil pressure is 43 to 95 psi @3000rpm, while the 3FE is the same at 36 to 71psi @3000rpm.
  11. instigator
    instigator
    255
    Nov 27, 2002
    georgia
    thanks drexx i guess i'll have to put the gauge in the port where the oem gauge is
