After looking at the tongue setup on my utility trailer, which seems suspect, I've decided it probably needs tweaked so looking for some advice.
The trailer is 6'x4' with an 2" angle iron frame, on leaf springs. At each end of the springs is a horizontal bar across the underside of the body, connected to the frame (it's the only underside support), the tongue is a single bar (channel approx 3" wide, 2" tall, 1/4" thick) which is welded onto the foremost horizontal bar and... onto the axle itself. This means that instead of the springs doing all of the damping the frame bends a bit, and the reason I want to change it.
I was considering just cutting the tongue bar off from behind the first horizontal support, but I'm worried I'll weaken it too much. Another option is to put in a 3rd support bar (2" angle iron) under the frame above the axle and welding the tongue onto that.
The distance between the front of the trailer and the existing horizontal is about 2ft, and the new bar would be approximately 3ft from the front.
I'll try and upload a photo of the trailer frame later, but for now he's a quick diagram that should show what I mean:
