high vacuum building up in my fuel tank
Discussion in 'Diesel Tech / 24 volts' started by mike, Dec 11, 2008.
  1. mike
    mike 82bj42 1st project
    2,277
    5
    Mar 12, 2003
    Toronto,Canada
    What can be the cause of high vacuum building up in my 87hj60 fuel tank? I can bearly remove the fuel cap when I go for refueling.
    Thx Inadvance
  2. roscoFJ73
    roscoFJ73
    13,047
    Media:
    3
    199
    Jul 22, 2003
    Perth Western Australia
    Go the right tank cap on?
  3. mike
    2,277
    5
    Mar 12, 2003
    Toronto,Canada
    I'm not sure. This cap came with the truck. I will purchase a new one from Toyota to see if it makes a difference. Thx
  4. seapotato
    seapotato
    4,264
    241
    Jan 16, 2005
    Lacus Oblivionis
    mine does the same( 87 bj70, but similar deal)
    I know the reason mine does it, there's a pile of vent lines that come off the tank, and some of them were rotted off so I plugged them so crap didn't get into the tank. Ever since, big vaccuum, gas cap is a bitch to get off, but doesn't seem to affect the way the truck runs, so I can live with it.
    So, I'd have a look at the other lines that come off your tank.
  5. mike
    2,277
    5
    Mar 12, 2003
    Toronto,Canada
    Good idea, I'll have a look at all the metal lines that come off the fuel vapour separator. Thx
  6. mike
    2,277
    5
    Mar 12, 2003
    Toronto,Canada
    I found the problem-- your right. One of the steel line's ends was pluged up. I unpluged it and the tank's pressure is normal again. Thx
  7. Icefire
    Icefire
    163
    Mar 27, 2007
    London, Ontario, Canada
    Another good solution to that problem is to drill a small hole in the fuel cap.
  8. jzilla
    jzilla
    1,632
    44
    Feb 26, 2003
    Edmonton, Alberta (for now...)
    I just replaced my tank and 2 of the lines on the truck were rotted so I plugged the hoses as well.
    Looks like another one is leaking so I will have to plug that as well! Truck runs fine but could you not also run a hose up into the body somewhere? The gas cap idea sounds like it would be good to. So are the vent lines only so that the tank does not implode?
  9. mike
    2,277
    5
    Mar 12, 2003
    Toronto,Canada
    The imploding is a defineate reason for the one of the vent lines----the longer on that goes over the rear axel. My tank has normal pressure after unpluging that long vent line.
  10. jzilla
    jzilla
    1,632
    44
    Feb 26, 2003
    Are you talking about the steel line that does a loop and then goes under the body to the drivers side?
    Mine is just rusty so I cut it shorter several years ago. Never had a problem.
  11. mike
    2,277
    5
    Mar 12, 2003
    Toronto,Canada
    That's the one. I cut mine shorter also. Mines working fine now. Thx
