Help ASAP
Discussion in '40- & 55-Series Tech' started by Mavric1298, Feb 10, 2003.
  1. Mavric1298
    Mavric1298
    163
    Oct 28, 2002
    I've got the engine sitting on the crane, without the tranny, and it doesnt want to come out.  I have everything off it, the mounts, 4 tranny bolts and all the bits and peices off the engine.  It moved about an inch forward and now will just move a lil bit back and forth...anyone?!?
    87 fj60
  2. Erics75
    Erics75
    81
    Jun 14, 2002
    If you have the tranny out, bellhousing off and front mounts off I can't think of much else to hold it in. Did you make a complete check all the way around the engine and look for anything that might be interfering or binding? It's got to bee something simple that was overlooked.
  3. Mavric1298
    Mavric1298
    163
    Oct 28, 2002
    The tranny was still in, but the shaft was just sticking a little bit, just gave it a few good pulls and she popped out, problem solved! :D
  4. FJ_MONSTER
    FJ_MONSTER
    102
    Dec 13, 2002
    "HEY MAW PULL HARDER!!!!" :D
  5. Mavric1298
    Mavric1298
    163
    Oct 28, 2002
    New problem!
    I also just figured out the mystery of hwy i couldnt find a flywheel inspection cover that fit.....Some dummie put a 3f bellhousing on!  Is this right?!?! and if so why did the dealer try to order one for a 2f housing?  Second question, if i do the ranger overdrive with stock tranny combo for v-8 do i use this bellhousing or a chev. one, and what about rear motor mounts, use the old ones since i only removed the front ones?!?!?
  6. rick_d
    rick_d
    1,298
    97
    Apr 20, 2002
    that some dummy with the 3F bellhousing was Toyota son. 1985 and later US trucks have that bellhousing that has the ears for the H55 front input retainer and the tranny is also clocked to drop the transfer lower.
  7. Mavric1298
    Mavric1298
    163
    Oct 28, 2002
    When in 85....cause i made the mistake of typing 87 when i ment 85 :D (thats one of our other cruizer) she's an earlie 85, and the dealer kept getting me a 2f bellhousing flywheel cover...why would they do this if it should have a 3f one????
