Hey there,
i have a 94 fzj80 with 300000km on the clock that has an issue when driving it on petrol. At cold start it revs rough(up and down revving) struggles to achieve 1800rpm, sometimes it will stall. After holding the gas pedal down for a few seconds at about 2000rpm, the revs will hold and start dropping slowly as it should and eventually sit at about 550rpm. But it still idles a little rough(not as bad as start up though) and idles a bit lower than when i have it running on lpg. On warm start up if the engine has been off for 5-15 mins it will start fine and idle normally but still lower than when running on lpg.
Now, when i drive it it lacks alot of power! It also takes longer to change into the next gear. It kind of feels like the clutch is slipping but i know it not because it runs perfectly fine on lpg. After driving it for about 20km thats when things get worse. Between 2000rpm and 3000rpm while light acceleration the engine starts choking and theres absolutely no power or response. It feels like it wants to engage but it doesnt unless i push the throttle in almost to its max. Only then when it goes down a gear and the revs are over 3000rpm the choking stops but still lacks in power although revs are over 3000rpm. Once the choking starts i cant accelerate lightly. Only way to stop the choking is applying heavy acceleration. Its like its starving for fuel at the low end of the throttle. If i turn the engine off for about 5-10 minutes and the start it, itll run again for another 20kms before it starts choking again.
Ive changed the fuel pump and it did help a little abit. What i mean by that is before i didnt have to drive far before itll start choking. Changed fuel filter and fuel pressure regulator and still no change.
Has anyone experienced this before or know what i can do next to find the problem. Maybe injectors?
Vehicle is a 1994 fzj80 1fz fe 4.5 auto
Thanks
Thanks
