murf
Lifer
Phil did you ever swap out to the ipad in the 80? If so, What do you like about it over your previous set up?
Time to chime in...Android Gaia/Samsung Tab4 details:
- I bought a Samsung Tab 4 ~11 days ago from BB (14-day return policy, it's going back).
- I got a trial version of Gaia (customer service from Gaia sent me the link, I never saw it on the the Google store).
- I've recorded three trips via Gaia on the Tab 4, quick impressions as I need to hop back to the job:
- Tab4/Gaia combo isn't "perfect":
- 7" form factor probably isn't one that Gaia tests with via Android (possible iOS devices) - found myself having to routinely rotate the Tab4 to account for the popup keyboard Gaia wants you to interact with when saving pictures and/or adding/editing Notes against record(ing/ed) trips. The screen rotation, as it is with any "smart" device, can be pretty frustrating if it is something you have to repeatedly do and this is definitely the case during my limited use in the past ~1.5 weeks (yes, I'm impatient but that extra second or two delay each time I'm waiting for this frustrates the bejezus out of me)
Any experience with a stand alone hi output USB port?
I dumped the 3g/GPS iPad idea for a Gen II iPad with a Bad Elf for what Im told will be the best performance. The Bad Elf arrived today, down loaded the Bad Elf app, and Im up and running.
Looking into upgrading my Blue Sea dual USB port to a stand alone USB to get the full 2A. With only 1A Blue Sea gives the iPad it can barely keep up now. Any experience with a stand alone hi output USB port?
What Bad Elf are you using? I thought all of the Bad Elf models charge the Ipad through the Bad Elf, one power source.
Does this mean the USB chargers from Blue Sea are only capable for charging at 1 amp? I just bought a few planning on putting one up front and a few in the rear to keep the kids happy...
Here you go. Walmart $2.99. Can't beat it, works great.
One reason I use this is it works in my Cruiser and my airplane, which is 24v. T
http://www.walmart.com/ip/INSTEN-Wh...ung-Galaxy-S4-i9500-Note-3-iPhone-5S/28882299
- Dual USB Mini Car Charger Adapter, White
- Quantity: 1
- Note: Needs to pair with a USB charging cable(comes standard with iPhone or iPods originally)
- Use your car to charge any devices (digital cameras, mobile phones, USB accessories and more) that can rely on USB for power! This adapter plugs into your car's cigarette lighter jack to become a powered USB port
- USB car charger adapter charges your device from any standard cigarette lighter in any vehicle (Use together with USB charging cable)
- Patented circuit board designed to protect your valuable gadgets from short circuits
- Fit all electronic appliances that use a USB charging cable
- Input: 12V-24V
- Output: 5V/ 2.1A, 1A (Dual)
- Color: White
- Product names are trademark of listed manufacturer or other owners, and are not trademarks of eForCity Corp. The manufacturer does not necessarily endorse use of these products.
I have purchased several 2.1A dual plug in sources only to find it will not delivery 2.1A from one port when using the iPad.
I need to ask have you tested the output?
