gregnash
Anal Retentive Analyst
LOL.. yeah I would have to buy extra beer because every time I looked at that it would make me twitch something bad. And grampas ole' cough surp is the only cure!
As for the fuel tank I removed that multi-hose unit and plugged all the openings on the tank. I removed the restrictor in the filler neck and have the breather hose that goes to the top of the filler neck hooked up. With that I don't have any problems completely filling up the tank.
Do you have two vents then, the big vent that goes to the filler neck and then one more that goes up into the quarter? Do you have a sealing gas cap?
Without any vent to atmosphere and a sealing gas cap, I would expect the tank to develop vacuum to a point that it starves the motor.
I have the same setup as boots, there should be no buildup of vacuum due to the fact that the pump is sucking in only fuel and being that liquid is incompressible. If you were sucking in a combination of fuel and air, that could lead to a vacuum situation but the truck would be running poorly so you would notice it.
I guess my gas cap must not be a perfect seal then, because I had no starving issues. But as you mentioned, simply installing a length of fuel line with a filter on the end into the quarterpanel would eliminate the issue.
I love my Weller 40 watt kit.. superb iron if ya dont already have one.
Haha,you need a decal now!!
