Does anyone have any pics of their front drive shaft installed phase out? I'm going to reinstall mine and can't remember how it should be installed.
Thank you.
Thank you.
Thank you.
I just had the shaft rebalanced and joints replaced. The shop removed the DS so I didn't get a chance to mark it.
Phase should be set before balance. How it is mounted to the truck is not going to change the phase.
IH8MUD.com - View Single Post - In phase or out of phase?
Does this help? What is the "broken back configuration"?
Usually the two ends of the driveshaft are supposed to be parallel, with equal angles at the joints. In a broken back config, the ends are not parallel, but do have equal angles. If the middle of the shaft were horizontal, the ends would both turn down. That's the way the 80 front driveshaft is at stock height. It's unusual, and is the only reason I can think of that they would have put the driveshaft u-joints out of phase.
Interesting, and why would people change it for a lifted truck? I recently installed Js and I'm getting a slight vibe at high speed deceleration, I'm wondering if changing the phase might help?
When you lift the truck the front driveshaft is no longer in the same config. The angles become unmatched. That's why many people go with a double-cardan front driveshaft on lifts at or above 3", there is very little angle at the axle end, and the t-case end angle is increased.
If you refer to the picture above:
The front is out of phase, meaning that if you were to look at the yokes on the shaft, they are turned 90 degrees from the same plane, or out of pase.
The rear shaft is in phase, meaning that the yokes are in the same plane, or in phase.
This has absolutly nothing to do with how they are mounted on the truck. The only thing that determines the phase in/out is the drive shaft itself, not the u-joints or the way anything is mounted on the truck.
Simply put, imagine removing both u-joints and pulling the slip yoke apart. Then putting them(2 sides of the shaft) back together. If you were to align the yokes, thats in phase. If you were to then clock it 90 degrees, that's phase out.
Shane
Yeah I figured I will probably have to get a dc driveshaft, especially after I put in the front spacers and castor plates. The problem is trying to source one in Hawaii
there has to be a driveline shop on the big island. lock the center diff with your method of choice ( cdl or pull the fuse) and remove the shaft. Give the shop a flange to flange measurement, then ask them to change your shaft to a cv style. it will probably run you <$200 for the work, or if you choose to have a completely new one built, it will most likely run $400 or so.
