front brakes freeze up.
Discussion in '40- & 55-Series Tech' started by rusmannx, Jun 3, 2003.
  1. rusmannx
    rusmannx
    1,159
    13
    Feb 9, 2002
    HIT IT!
    my front left brake kept freezing up. i would have to get under and crack the bleeder valve to relieve the pressure. i had just rebuilt the brake cylinders on all four.
    after being annoyed long enough i cut off the front left tire. now it doesn't freeze up at all :) now the front right one does :(
    something upstream of the tires isn't letting the pressure relieve itself. could it be the master cylinder? brake booster?
  2. woody
    woody Internet Fireman Staff Member
    10,332
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    front disc brakes or stock drums?
  3. rusmannx
    rusmannx
    1,159
    13
    Feb 9, 2002
    HIT IT!
    oh, drums all around.
  4. woody
    10,332
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    hhhhmmmm....first guess would be the hose between the frame and the axle....2nd guess would be dirt in the master cylinder cup on that side, causing the residual valve to clog. Clean that first, then check the hoses for cracking/hardness/age and replace as necessary. A bad hose internally can cause fluid problems.
    if you had discs front, I'd make sure you removed the residual valve for that circuit, but that doesn't apply in this case...and since it's seizing on both sides, it's more likely not one of the two short axle-to-caliper hoses but the frame-to-axle hose thats the issue. IMO, if you replace one, replace all three while yer in there.
    Check for any crimped lines too....cheap-easy visual look.
