maxamillion2345
Franken-80
The pump gear IS timed to the cam gear. It is also keyed to the pump. But you can time the gear to the other gears wrong.
I was worried that the gear jumped a tooth before I marked the gears from not having the IP for who knows how long since I had it. But I played with the slop and can't get it to jump teeth so I am 99 percent sure its In the right spot. So now my question is do I turn the motor over till the keyway is lined up or do I turn the shaft on the IP accordingly?That picture is false.
That's what I have been reading. I guess my idea with it was being all my fords have had zf5s even my Powerstroke has one and I love the way they work! Except their syncros go bad easily because mine suckZf5s are kinda ****, nv4500 would be a significant upgrade, just my .02
Stock intercooled 7mm injectors for now. Still more fuel then the 9mm pushedWhat injectors did you get? I'm running PODs.
