Exhaust Leak
Discussion in '80-Series Tech' started by landtoy80, May 12, 2003.
  1. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    North Front Range, CO
    I have a leak where the exhaust manifold and front exhaust pipe gasket is. I soaped the joint up and it blew big bubbles. I think just removing the front pipe at the cat should be enough to replace the gasket. While I have it apart I will check the cats. Should I be able to see through them ( I got a new cat for the fj60 and it used several screans that I could see through)?
    Is there any thing else I should check while I have the exhaust off?
    kurt
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,564
    2,891
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Kurt,
    You can see thru a good cat, It will look like a screen door.
    You should be able to remove the pipe and leave the cat in place, but in order to see thru it you will need to remove the rear pipe too.
    The pipe to manifold gasket is a 90080-43036
    The front cat gasket is a 90917-06043
    The rear cat gasket is a 90080-43033
    Dan :beer:
  3. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    I have the cat gaskets as I was going to remove and check the cats. Usualy I would see that the other gasket is leaking after I have had it apart once. I beter check the manifold too.
    thanks
    kurt
