Can anyone confirm this works for the newer LX models with the updated interior?
Anyone use this one?Thanks for the great writeup! I plan on doing this install in the next couple of months.
Naviks unit is now $245 and the camera in the first post is currently not available. Most cameras will work as long as they have a composite video output.
FWIW, Naviks recommends the below 2 cameras:
Pioneer NDBC8 ($79.97)
Amazon product ASIN B00XBDBQ8S
Kenwood CMOS-230 ($87)
Amazon product ASIN B00WH0R2Y8
Any follow up ideas on using the HDMI port? I like pi.Did this install yesterday and I can confirm the nav display does seem blurry. We've never used this since the GPS is broken so I've not got a lot of reference here.
During the install I did find that the GPS wire was snapped off from the connector into the navigation box so it may be more of a nuisance once I fix that.
Also to update this post, BTW thanks @bludy1 - this has been on my to-do list a year now. The newer NAVIKS units come with 3 inputs. The backup camera that is triggered by 12v reverse input, a second RCA input as well as an HDMI input that is triggered by the included momentary switch to cycle through them. On the third click you're returned to the factory nav screen. I'm going to play with a Chromecast and RaspPI as HDMI sources and most likely a front facing camera of some sort for the other input.
View attachment 1906728View attachment 1906729View attachment 1906730
The Naviks (NK-2300) does work on a 2003 LX470. The wire colors, however, are slightly different. It seems from 2003 they started to use different colors for wiring. Naviks does a good job of labeling all the wires on their harness. Naviks Harness (NKH) ACC wire attaches to the 18th pin NAV ACC wire (bland olive with pink markings). The NKH Ground wire attaches to the 17th pin NAV Ground wire (off white/yellowish w/black stripe). Reverse trigger wire and Male RCA power wire (comes off the Male RCA) attach to the 14th pin NAV Reverse wire (Red w/black stripe and pink markings). Like bludy1 mentions the Reverse Trigger and RCA Power needs to be wired together to the NAV Reverse wire.
In the 03' model year the reverse light was moved closer to the center of the tailgate. The reverse lights are connected by a pin connector harness and not like the usual way a bulb is connected. Sorry I was in a rush and didn't get a photo of the harness. I have to replace some bulbs and will get photos and post so that anyone trying to do this on a 03' to 06' will have some clarity.View attachment 2188020View attachment 2188021
