Thread Update
This is a great fix outlined by Keith and thought I would add a few pics of the process.
I thought my motor was toast as I could not get it to budge or make a sound. Multimeter showed it was getting juice so I assumed it was burned and started looking for another motor. After seeing the prices associated with 40 year old windshield wiper motors, I thought I would give it a shot to see if it still had life in it. I was more than happy with the outcome.
As listed by Keith and per Coolerman, jump the wires from your plug to the battery. Positive first and then your high then low wires (Test high and low separately). I got the motor whirring when I hit hit the high switch but nothing with the low (first pic). Decided I could live with high only if necessary.
Take the screws out and pull out the wiper shaft and what you see in pic 2 is the junk that needs cleaning. 40 year old grease and dirt was thick. Lots of paper towels help.
Pic three shows the motor out and mine had dust/dirt/grit all around the contact points. I took some 220 grit sandpaper and LIGHTLY brushed the contacts and the coil.
I repacked the gears with bearing grease and started putting her back together and then discovered the original problem: The windshield wiper shaft (with attached gear) on the passenger side was seized! The gear would not turn at all. I sprayed PB on her and let it sit a while but it took a pair of channel locks and a plumbers wrench to get any movement. If you have elf finger, there is a tiny little clip that can be removed and then you can pull the shaft but I could not get that sucker off to save my life. I sprayed with PB, waited, slightly worked the gear and repeated (for a day). FINALLY, the PB fully penetrated the shaft and she loosened up like a skank on prom night.
Put it back together and I now have functioning wipers and saved a bunch of cash. Cleaning the contacts brought the low speed back to life and it's now working great.
