Cutting glass tubs
Discussion in '40- & 55-Series Tech' started by ScottFJ40, Apr 8, 2003.
  1. ScottFJ40
    ScottFJ40
    536
    Jan 30, 2003
    Just wondering what you guys with glass use or would use to cut the tub. I'm gonna put some "you know what" flares on the back, and know I need to cut a little.
  2. Markh
    Markh
    173
    Feb 8, 2003
    Los Alamos, NM
    I used a pneumatic cut-off wheel to do mine. Basically its a die grinder with a 3" cut-off wheel and a shield. It cut through fiberglass with no problems and left a smooth edge. You do have to be careful not to let the wheel catch and go where you don't want it to.
  3. toddslater
    toddslater SILVER Star
    1,498
    2
    Oct 31, 2002
    Kennett Square
    Just a little trick for you. Get some 3/4 inch masking tape and use it to tape out your desired wheel opening line. Use the cutoff wheel as Mark said to rough it out to @ 1/8 inch of your tape line. Finish the last bit off with 36 grit on a hand sanding block (maximum control if your not used to this) or use a small grinder or air file with 36 on it if you have and are comfortable with them.
  4. schleb
    schleb
    52
    Oct 11, 2002
    Home Depot sells jig saw blades that are coated with carbide grit, with a variable speed saw and some patience they work great on fiberglass.
