Hello everyone,
My name is David, I am from Costa Rica and this is "my" slow and long term build thread. The car is a 2016 Toyota HZJ79 dual cab (No pics right now, sorry). Why "my”? Is because the car is not 100% mine. In fact, is a "self bought gift" for my dad, but I am a 0.5% owner (Or maybe less, but is enough for me ) and my dad doesn’t know how to start mod this car, so here is where I help.
Anyways, it came with a 1HZ so for me is a totally different animal (I drive a slightly modified Jeep TJ with the 4.0). My dad and I prefer a petrol V8 engines, but sadly the 1HZ was the only option for J7x in the Costa Rican market . I see a 1UZ swap in a near future but it will be stock for now (or at least when the warranty expires)
Right now I have a lot of questions about the car, so maybe someone can help me:
1- The car didn’t come with tachometer (weird for a $60k car), so, there is any option or mod for add one? My first thought was use the OBD as a “signal provider” for a external scanner (Like ScanGaugeII). I tested with my OBD scanner but it just doesn’t “read” the ECU (BTW, the 1HZ has a real ECU? Because it is mechanical injected and I don’t see any specific sensor like a O2 or EGT or something similar) and I read somewhere on internet that Toyota use a different "OBD" protocol, or something called M-OBD. My next option is an “Universal Flywheel Tachometer Interface” from Dakota Digital, but it is way too complex for just one gauge, but still an option. And the last option is “pick up” a signal from the alternator, but I don’t know if my alternator is compatible for that and also it is way too “inexact” for use as a tachometer. Also, I don't know if the injection pump come with the "RPM picker" because i saw a green wire coming of, but i think is just the cut-off solenoid.
2- My next question is about tires and rims/wheels. It came with 16x15.5 steel “split style” rims and 7.50R16LT (maybe 30.5x7.5x16?) “tube type” tires. The first thing on the list of mods for the car is change tires, but when I saw the rims I knew this won’t be easy. I am pretty sure that is hard to find at least a 33” M/T tire for this rim, so change them is a possible option. What are the specs (offset, backspace, stud pattern) of these rims? Or where I can find tires for these rims?
3- The car came with some connectors not plugged and this is most for curiosity. Where should be these connectors plugged? Anyone has the electrical diagram for this car? Pics:
Behind the Headlight
Next to the firewall
Same as above
Same as above
Same as above
4- The car also came with few blank spots for switches. What are they for? Is just for fill them with other switches Pics:
What mods has right now? Well, it has a Kenwood KDC-MP162U from “factory” (I am sure that the dealer installed it) and that’s it. But still more to come.
I think that's all...for now And sorry for the crappy, no-light pics and if I committed gramatical errors (or horrors). The English isn't my main language.
Thanks in advance.
Same as above
Same as above
Same as above
Thanks in advance.
