Iv been looking into this problem for about a year now since I got my 74/40 on the road. What it's doing is it will pull one way and switch back and forth at random and if someone else drives it they almost go off the road. This problem gets worse as tire size gets bigger/wider. A bit of back ground. I put a sag power steering 74 chevell box and a 70 Chevy truck pump, with a s10 column and I got the spud, intermeadite shaft, 1.5 inch drop pitman arm, drag link, upper tie rod end and mount plate all from btb. It's got a 4 inch lift and 4* axle shims. Iv also put 83 fj60 disks up front. All seals have been replaced and the 3 remaining tre are the smaller 40 ends but are new and have less than 5k on them.
