CDL Switch
Discussion in '80-Series Tech' started by DRTDuck, Apr 23, 2003.
  1. DRTDuck
    DRTDuck
    624
    9
    Mar 28, 2003
    Boulder, CO
    I'd like to install the CDL Switch, however the reccomended place, to the left of the flasher switch, is taken by the factory alarm system light.
    Has anyone done this with this factory alarm insert?
    Are the wires long enough to put either the CDL Switch or the alarm insert lower in the console?
    Or do I even need the alarm insert?
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,603
    2,981
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Byron,
    IF you have a true VIP, yes you want the light. It also contains the glass breakage sensor. I don't recall the orientation of those when both are present in a 96. Beo has locks and I think also VIP. Lets ask him.
    Beo, what say ye? :bow:
  3. Taz
    Taz
    342
    Mar 27, 2003
    San Juan Capistrano
    On my 97 the wires for the alarm light and sensor were plenty long enough to move it down to the left of the rear heater switch. Easy mod, takes about 10-15 Minutes. Slee has explicit instructions on how to remove the dash, which will save you a lot of time and frustration.
  4. DRTDuck
    DRTDuck
    624
    9
    Mar 28, 2003
    Boulder, CO
    Yeah, it is a VIP with that sensor as well. I've had the dash of a couple of times, so no big deal.
    I'll check the wires out as Taz suggest.
    Would that sensor be less effective if it is down low instead of higher up on the dash?
  5. Curran
    Curran SILVER Star
    824
    5
    Mar 27, 2003
    Frederick, MD
    Another option is to move the rear defroster down next to the rear heater.  Then use its spot for the CDL.  I thought it made more sense to group the rear heater and rear defroster next to eachother. (That and I couldn't get the VIP thing out of the dash. :ugh:  )
  6. Jim_Phillips
    Jim_Phillips
    723
    1
    Mar 27, 2003
    Ingerland
    I don't know if this pic will give you any ideas but it's a UK model (rhd) Our layout is probably different to yours..
    Jim
  7. DRTDuck
    DRTDuck
    624
    9
    Mar 28, 2003
    Boulder, CO
    Thanks, it looks like I should be able to move something to make room for it.
    Curran-
    I like your idea of moving the rear derost down.
  8. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    Somewhere in the foothills...
    Byron,
    I moved the VIP sensor and LED to an open spot on the bottom row as Taz mentioned.
    If I were doing it again, I would keep the alarm on the top row and move another switch like Curran did.
    The problem with moving the alarm lower is that it reduces the visibility of the LED which is supposed to be a deterrent to any would be thief. On mine, they would have to be 7' tall, walk up close to the window, and crane their head around to see the LED flashing. They get a little better view from the PS. :G I tested the glass breakage sensor and it still works OK in the lower position.
    -B-
  9. DRTDuck
    DRTDuck
    624
    9
    Mar 28, 2003
    Boulder, CO
    B-
    Was your testing of the glass breakage sensor intentional?
  10. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
  11. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    You'll notice Jim's VX has a much different radio that what we got in the US "Premium Sound" versions. His also came with the climate control A/C availaible only on 40th and CE's in the US market.
    -B-
  12. Jim_Phillips
    Jim_Phillips
    723
    1
    Mar 27, 2003
    Ingerland
    I also now have the Dash Cup Holder (just in case you were wondering what a DCH is (signature))
    Also, my wood is real wood. Am I right that only the US Lexus comes with real wood?
    Sorry to see the Thong has gone - it''s probably for the best 8)
    Cheers, Jim :beer:
  13. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    Jim,
    >> Am I right that only the US Lexus comes with real wood? <<
    It appears that you are correct. I still want to see a Lexus close up so I can tell the difference.
    I've located the THONG! MTS (Mike) should have it today with his S/C. I told him he could keep dirty-legs, just send back the thong. He said he would. :G
    -B-
  14. RavenTai
    RavenTai
    6,048
    16
    Nov 16, 2003
    Dixie co. Florida
    the lexus is just better plastic not real wood, but at least it holds up beter than the US LC
  15. sea2skydad
    sea2skydad
    208
    4
    Nov 24, 2003
    Does anyone know if the VIP sensor has a sensitivity adjustment? I rap on the glass with a key and it doesn't trigger the alarm. I'm hesitant to amp up the test any harder, I hate replacing glass. Thanks, Greg.
  16. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    Am I in a time warp or did someone dig up a year old thread? :D
    Anyway, yes, the glass breakage sensor can be adjusted. There is a recessed screw in the side to change the sensitivity.
    :cheers:
  17. sea2skydad
    sea2skydad
    208
    4
    Nov 24, 2003
    Thanks, Dan. Now you've got me humming tunes from Rocky Horror. Hated that movie. I thought the popcorn was for eating.
  18. Rookie2
    Rookie2
    3,002
    51
    Dec 15, 2003
    Knoxville
    I noticed in a previous pic that their CDL switch was located where my glass breakage/security light is. So in that case I guess I would need to locate the CDL switch in the panel left of the steering column..? The tie-in for the CDL switch is behind the center dash panel somewhere right?
    Thanks,
    Rookie2
  19. landtank
    landtank SILVER Star
    18,422
    595
    Mar 27, 2003
    Groveland MA
    When you take the dash apart you'll see that the harness for the CDL switch is part of three others. The easiest spot is where your alarm sensor is. I chose to remove the tape from around the harness so I could separate the CDL part from the other 3. This gave me enough room to place the switch along side the rear heater fan switch. I prefer it down low and out of sight as starngers might press it wondring what it does.
