jestlurnin
Hey folks have a couple questions.
I finally broke down and took the Mrs's 2000 LX470 into a mechanic to have the timing belt, water pump, and cracked passenger side exhaust manifold replaced. I could most likely do this myself if I had the time, the only problem is I don't have the time. And if I do have time I'd rather spend it wrenching on my FJ45.
They dug into it a bit and said the camshaft seals were leaking as well. I've seen on lots of threads that the camshaft seals are commonly replaced when the timing belt and water pump are done. So I figured well as long as they are in there....
I am being told that on the LX's that the camshaft actually has to be removed to change the seals thus the high labor costs I was quoted. Can someone confirm that the camshaft has to be removed to replace the seals? I feel like I've seen in threads that the seals can be replaced rather easily once in there and I don't feel like I've ever seen that the camshaft actually has to be removed!
Any advice would be very welcome!!
