Backfiring 60--- Lean Carb?
Discussion in '40- & 55-Series Tech' started by Guest, Feb 27, 2003.
  1. Guest
    Guest Guest
    Quick question (Hopefully):
    My 60, will backfire for a block or two after giving it gas and shifting until it has warmed up a bit, then the backfiring goes and... is this due to my carb running too lean.. someone mentioned that might be my problem... any thougths?
    Rob
  2. wayne_fj40
    wayne_fj40
    252
    Dec 31, 2002
    My response to that would be it is running to rich,And that is why after it warms up it stops because then the choke is off and has leaned out enough
  3. Guest
    Guest Guest
    Jim C rebuild time?
    Is there a moderately easy way to adjust how rich it is running without a rebuild, although it probably needs it.
    Rob
  4. Degnol
    Degnol
    8,123
    Media:
    16
    6
    Jan 22, 2003
    Kansastitty
    Get yourself 1/2 gal of Chemtool Carbdip and a good kit from the Autoparts store and an old bathtowel and do it yourself. I'm a moron and I did it. It's just replacing parts except for the float level adjustment and the idle mixture screw. Carbdip...18.00,carb kit...14.95, two hours time proving to yourself that you can do it...you know
  5. bernefj60
    bernefj60
    169
    Dec 18, 2002
    Rob,
    There are a few reasons this is happening:
    1. your carb needs to be rebuilt
    2. your carb needs to be rebuilt
    3. your carb needs to be rebuilt
    Seriously, though, the truck has a bunch of miles on it, and LC carbs are notorious for gumming up if you don't drive them alot or get on them enough.
    Try the old italian tune up. Fill it full of junk and head up a mountain in 3rd with your foot into it. IT'll clean out the carbon and pull the gunk from the carb. YOu might also check your PCV valve, your Air cleaner, and that you don't have any vacuum leaks.
    I'll be down in a week or two and we can take a look.
    Easy way would be to have Jim C. rebuild it, but then you've got the header question, etc, looming over your head.
    Rob
