Awful MPG 99 4Runner Limited
Discussion in '05+ Tacoma, T100, Highlander' started by badams1897, Jun 8, 2011.
  1. badams1897
    badams1897
    24
    Jun 1, 2011
    I am getting horrible gas mileage in the 99 4Runner like 12. Am I doing something wrong? The engine runs great, sounds great. I have kept my foot out of the gas this tank hopefully it will improve. Am I in 4wd and I do not know it??
  2. raydouble
    raydouble
    1,521
    1
    Feb 11, 2008
    Rochester, WA
    Is the check engine light on?
    How many miles?
  3. IanB
    IanB SILVER Star
    2,147
    295
    Jan 23, 2010
    Winnipeg, MB
    Are you talking city or highway driving? I don't think that's outside of what you should expect around town unfortunately.
  4. SRSRunner
    SRSRunner
    25
    Jun 3, 2011
    Chestertown, Md
    even with the ECT on?
  5. NOR CAL CRUISER
    NOR CAL CRUISER
    67
    Mar 8, 2011
    RED BLUFF CA
    12MPG is a little low. my 98 4 runner gets about 14mpg, 16mpg at its best! check you t-case make sure your not in 4-high and dont know it. my 4 runner has a light in the dash that tells me its in 4wd.try a tune up, oil change,plugs wires.tire pressure can also affect mpg.
  6. badams1897
    badams1897
    24
    Jun 1, 2011
    No check engine light at all, new O2 sensors 177k miles, new oil, new diff fluid, new tranny fluid, new bearings, 40PSI in tires, new tires. New plugs, and wires done at 120k mi. ECT on or off better?
  7. raydouble
    raydouble
    1,521
    1
    Feb 11, 2008
    Rochester, WA
    People have reported better MPG with it on and not putting your foot into it.
    Ever change the fuel filter?
    12-15 is fairly standard for in town driving.
  8. badams1897
    badams1897
    24
    Jun 1, 2011
    So I ran it until fuel light came on filled it up and it only took 13 gallons. I drove it well past the E with the fuel light on pushing it. How on earth can there be 5 gallons in reserve? I think my gauge is off.
  9. raydouble
    raydouble
    1,521
    1
    Feb 11, 2008
    Rochester, WA
    From the FAQ
    TSB EL010-00 Fuel gauge inaccuracy
    TSB EL010-99 Fuel gauge recalibration procedure (text description of the procedure in the .pdf file as I couldn't find the original)
  10. Brake Weight
    Brake Weight
    560
    64
    May 27, 2011
    South MS
    Do you have a K&N filter? The oil messes with the MAF sensor causing bad mileage.
  11. SC T100
    SC T100
    48
    8
    Nov 30, 2010
    Also, if you have taller-than-stock tires and you are reading from the odo, your calculation will be off (low mpgs...it will read fewer miles traveled). If you have oversize tires, check your distance with a GPS.
  12. KayakPanic
    KayakPanic
    571
    Nov 28, 2008
    Townsend/Big Sky, Montana
    redo plugs and wires if its been 50-60,000 since last changed, also change air filter and fuel filter.
    If it has a distributer cap and rotor do those too.
    If it is an auto, you might see if the AT filter(s) has been changed or cleaned. Usually a tranny flush does not include filter changes...
  13. raydouble
    raydouble
    1,521
    1
    Feb 11, 2008
    Rochester, WA
    Plugs are due every 30,000.
  14. RobMikulskis
    RobMikulskis
    28
    May 4, 2011
    Virginia Beach
    check the air filter, maybe a small investment in a throtle body spacer or a cold air intake would do the trick
  15. Duane
    Duane IH8MUD Wookie
    704
    Nov 21, 2006
    Medicine Hat
    What does your tailpipe look like? black and sooty or very little residue and grey/shade of the pipe material?
    Does it seem to coast fairly well when you get off the gas or does it seem like a brake is dragging?
    Is it sluggish to drive? Acceleration ok?
    Have you ever cleaned the injectors/ran cleaner through it?
    Ever cleaned the MAF sensor?
    I assume it is a 3.4L V6?
    Anyone ever heard of a converter plugging up on these units?
    What rpm does it run at what highway speed... wondering if lock up converter is working and OD? auotmatic I assume or a standard transmission?
  16. badams1897
    badams1897
    24
    Jun 1, 2011
    It drives ok, coasts fine, accelerates fine. I am going to look into fuel gauge and put a new air filter in.
  17. Duane
    Duane IH8MUD Wookie
    704
    Nov 21, 2006
    Medicine Hat
    Not sure how the accuracy of a fuel gauge helps mileage? :hmm: range yes.
  18. Brake Weight
    Brake Weight
    560
    64
    May 27, 2011
    South MS
    There was a run of F150s that had gas caps that would go 'bad' causing poor mileage. Don't know if Toyota ever had that issue, but my VW threw an error once with a dash light that's an icon of a gas cap. I had to get it reset, but mileage wasn't affected.
  19. SRSRunner
    SRSRunner
    25
    Jun 3, 2011
    Chestertown, Md
    12-15 is avg from what ive read for "town" driving, I run with my ect on and have yet to get worse then 16. I avg almost 18 The maf could be dirty, but theres no way its going to affect your mileage that much, if it was bad enough to cause problems it would throw a code. Youve already addressed the plugs etc- which thats about all you can do, maybe check em since it easy to do.. Guess your one of the few who gets poor mileage.. read up on it, theres plenty of guys in that 12-15 range, and as high as 21-22.
  20. badams1897
    badams1897
    24
    Jun 1, 2011
    Update - I was figuring out mileage based on 18.5 gallons use like an idiot. I filled up, drove, filled up again noted gallons of fuel used and I am averaging 18/19 MPG highway. :) My bad.
