Anyone got a Knuckle centering SST to rent
Discussion in '40- & 55-Series Tech' started by citabria, Jul 28, 2003.
  1. citabria
    citabria
    26
    Mar 30, 2003
    Need the SST 09634-60013, Steering Knuckle Centering Gauge. Doing a mini truck swap to my FJ40 and need this tool to center the knuckle/axle. Unless someone out there knows of an alternative way to do it?
    Straylight
  2. pismojim
    pismojim the Dude abides...
    1,060
    16
    Oct 18, 2002
    Pismo Beach
  3. Medusa
    Medusa
    416
    1
    Jun 17, 2002
    I have one you can "rent" for the price of shipping to and from 97701
  4. citabria
    citabria
    26
    Mar 30, 2003
    Done!
    I'm in Indiana.
    Dennis P. Kane
    C/O Michigan City Airport
    1300 N. HWY 212
    Michigan City, Indiana 46360
    Redoing my 1975 FJ-40 from the frame up and ready to put the Mini knuckles on.
    Let me know what it will cost and I will send you a check for the shipping, deposit if you want, and enough for a case of long-necks.
    Really appreciate it.
    Dennis
  5. KNUCKLEDRAGGER
    KNUCKLEDRAGGER
    124
    Jun 23, 2002
    Just how important is it to use one of these tools ? If you can get the preload right with a fish scale, what additional benifit is the special tool ? Im guessing that alot (most) of us dont use this tool....or am I wrong ? I did a min truck disc conversion without it...the aligment shop said it was almost dead on when I took it in, are they missing something that they should be checking ? I dont need any stray telephone poles jumping infront of me !
    Thanks
  6. Medusa
    Medusa
    416
    1
    Jun 17, 2002
    You can have the correct preload and still have the whole spindle assembly off-center.
  7. KNUCKLEDRAGGER
    KNUCKLEDRAGGER
    124
    Jun 23, 2002
    Medusa:
    How would I know....would the truck handle differently ?
  8. Greg_B
    Greg_B
    4,287
    50
    Mar 28, 2002
    As mentioned, yuo can get the correct preload and not have a centered axle. If you are assembling a bare bones axle housing, and have no record of the stock number and thickness's of shims top and bottom, then to get the axle to center through the oil seal you should use the SST, or the home brew version.
    Your truck will not handle differently, you will just start pucking gear oiled knuckle grease out the knuckle housing, as the axle will not be centered to the oil seal.
    One good reason to keep 4 baggies on hand when tearing down to the knuckle bearings. Mark each bag and put the appropriate shims in each.
    hth's
    gb
  9. Pin_Head
    Pin_Head
    13,736
    1,304
    Feb 6, 2002
    OC, CA
    [quote author=knuckledragger link=board=1;threadid=3974;start=0#msg29973 date=1059805400]
    Medusa:
    [/quote]
    It won't handle differently, but the inner axle seal will leak.
  10. KNUCKLEDRAGGER
    KNUCKLEDRAGGER
    124
    Jun 23, 2002
    That sucks...I really dont want to tear all that goey mess apart again, I think I'll wait till they start to bleed.
  11. xumFJ40
    xumFJ40
    376
    May 9, 2003
    Tex..as...Ohhhh...Texas!!!
    Hey gang,
    This may be a stupid ? but do the mini truck birfs have fine or course splines? I am about to do the mini-truck conversion on my '75 and was wondering if I can keep my hubs. I am running course spline Aisin hubs currently.
    Thanks,
    -R
  12. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    Minis are fine spline. Disc LCs are fine. Drums are coarse, as you know. I'm in the same predicament.
  13. xumFJ40
    xumFJ40
    376
    May 9, 2003
    Hammer,
    That is what I was afraid of....Anyone what to buy a set of course spline Aisin hubs :D
    -R
  14. denis
    denis (O) toyota nut (O) SILVER Star
    1,154
    Nov 11, 2002
    buried in a pile of yota projects
    [quote author=xumFJ40 link=board=1;threadid=3974;start=0#msg30215 date=1059976790]
    Hammer,
    -R
    [/quote]
    Coarse aisins ? do such things actually exist ? What about $15 for both ?
  15. xumFJ40
    xumFJ40
    376
    May 9, 2003
    Yep...They exist
    I have a set that came on my '75 FJ40.
    I will be swapping to a disk setup over the next month or so.
    I think that I will hang on to them for now... :D
  16. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    Does anyone know if coarse spline birfs and hub lock mechanism can be used on a fine spline rig. If my buddy breaks will my spares get him home.
  17. bad_religion_au
    bad_religion_au
    2,212
    Apr 24, 2003
    so mini truck (hilux to me) free wheelers will fit my 76 disk brake fronts??? if so, that may make the hunt for new free wheelers easy
  18. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    Anyone here make that part? If so, how did it come out?
    I gotta find one of these or make one up asap. Anyone got one they want to rent or sell?
  19. dustin
    dustin
    701
    Oct 19, 2004
    just so you all know- that tool is quite a math project to get just right. I did it and it was a beatch.
    You will need calipers that fit over your knuckle and measure in millimeters too- not easy to find.
    I was asking for the directions to use this thing a few months back, and some people sent them to me. I think Woody may have even posted them on the tech links?? Not sure. I can email it to you if you want it. Its a scan of the Factory service manual.
    -Dustin
  20. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    The later the manual, the better the directions for using the centering tool.
    You will need an 8" caliper whether you use the Toyota tool or make your own. I had to get one from mcmaster.com.
    Every chassis manual up to '89 has the procedure.
