- Thread starter
- #21
Thanks guys for all the input.
I finished the CB install this evening. Opened the case and installed a pigtail using good quality coax, good shielding to the case on the inside. Shielded plug on the end of the pigtail. Plugged the big hole in the case with a plate with a small hole for the coax. JB Welded the plate to the inside of the case. The pigtail is about 6" long and used a wire tie for a strain relief. Good solder joints everywhere with heat shrink.
Removed the PS seat for access to dash and to get to unswitched +12v. This is the location my 2nd fuse box will go when I install it and the 2nd battery so that is why I selected the PS seat for power. Soldered the connection, taped, and slipped it back in the seat wiring harness.
Antenna is running under the Husky liner, between the 2nd row seats, under the mat to the center console, then up to to the dash. Someday I plan to run the coax next to the PS frame rail.
Radio fits well and looks factory. Thanks to all and special thanks to Christo for letting people know the CB model to use and where to mount it. That saved a lot of time but it still took me most of the day.
-B-
(PS - Pitched a neighbors 12-man tent in the back yard. It's my son's 11th birthday party. Never laid eyes on this tent before. No instructions. Gusts to 30mph. Started at dusk, finished well after dark. Eight 11 year old boys "helping." I'm too old for this and I need a drink!.)
-B-
