- Location
- United States
Up for sale is my 80 which has been an amazing truck to me for several years.
This truck was my daily driver for several years until my commute doubled in distance, then it became a toy and weekend warrior, however I no longer have enough time to enjoy it.
It is a great truck that someone will be lucky to have, below is a list of maintenance and modifications since I purchased it in 2010 with 151XXX miles from Maryland.
The truck is currently located on Toronto, Canada and I am happy to help with shipping or delivery if required.
1997 LEXUS LX450, TRIPLE LOCKED
• 192XXX miles, oil changed every 5000 miles
• PHH – 30,000 miles ago
• Most coolant lines replaced with silicone hose
• Coolant flush (Toyota red) and thermostat replaced
• Cap, Rotor, Wires, Plugs – 30,000 miles ago, Plugs again 500 miles ago
• New Battery – summer 2015
• A/C Compressor, Dryer, Expansion Valve, Evaporator replaced - 5000 miles ago
• Both belts – 15,000 miles ago
• Front main seal and oil pump seal – 15,000 miles ago
• Catalytic converter – 20,000 miles ago
• Cat-back exhaust (bosal) – 10,000 miles ago
• O2 sensors (x2) – 5000 miles ago
• Starter – 5000 miles ago
• OME LIFT, Front - 850J/60070L, Rear – 863/60020, with Steering Dampener and caster correction bushings. – 35,000 miles ago
• Sway bar drop blocks, 2” aluminum
• Stainless Extended Brake lines - 35,000 miles ago
• Diff breather Extension to engine bay
• 7-pin mod
• Rotors/Pads/E-brake shoes - 25,000 miles ago
• Front & Rear axle service, all seals changed, shafts swapped, fresh fluids – 5000 miles ago
• Transmission/Transfer case oil change – 10,000 miles ago
• 315/75/16 Kelly Safari TSR (x5) – 35,000 miles ago
• Steel roof rack, home built, Line-x coated
• Light bar with 2 Hella Optilux 35w HID flood lights
• Windshield gasket – summer 2014
• LED dome lights (x3)
• JVC KD-AR959BS headunit
• Pioneer speakers front and rear
• New speaker wire throughout (old removed)
• Excalibur anti-theft system
• Hitch receiver built into rear bumper 2” with 4-pin trailer harness
The only items that need attention:
• Windshield is cracked
• Exhaust has a leak
• Drivers seat leather has begun to crack
If you have any further questions, I'll be happy to answer them.
Asking $10,500 CAD or $7,900 USD
• 7-pin mod
