Hey,
I recently bought this 91 land cruiser with 213k off of craigslist. It want running when I bought it.
I thought it would be a reasonably easy fix but has proven a little harder than anticipated.
When I got it, it would turn over but not start. The previous owner had pulled the wiring loose on the MAF and had pulled the top off to resolder it. He hadnt sealed i back very well, when I sealed it back up I was able to get the vehicle to start. Now, I have to peg the pedal to the floor to get it to start. It will start and run but not idle and soon as I put it in gear it dies.
I have cleaned the throttle body, cold start injector, MAF and IAC. all of the above tested ok except that I cant get the IAC to pull in and out when I put power to it like the Toyota repair manual suggests.
Ive also tested the fuel pressure, no problem there. Also tested ignition coil, and igniter and they were fine as well. Ive replaced the plugs and cap and rotor.
Obviously Im missing something but Im not sure what. Im not very familiar with Toyotas in general either.
Any thoughts are appreciated.
Thanks
Thanks
