bj40green
Tssss, tssss
I think I will just wire a lamp between the 2 wires and be done with it.
Daryl
If you do that the bulb will lit up at max brightness and your plugs won't glow. In this case the light bulb is the current limiter for the glow plugs. Right now you're cooking your 8.5 Volt plugs with 12V, which can be fine as long as you don't glow them to long. Better to buy the 12V 4 cyl. controller 28550-46021 (open model) or the 28550-57010 (closed model).
Or if you want no controller, change your plugs to 10.5 Volt.
You don't want an exploded glow plug tip in your cylinder!
Saludos
Rudi
If you decide for the light bulb and you want your plugs glow correctly, here is the math: 12V battery minus 8.5 Volt glow plugs is 3.5 Volt for the light bulb.
Your 4 plugs are pulling 40 Amps. So 3.5Volt times 40 Amps makes a 140 Watt light bulb!
