I posted this in the 60 section but can't get a response. I am trying to tension the fan belt on my 2h. I haven't got this on the road yet so I don't know that I do or do not have all the parts needed.
The alternator just doesn't seem to have the right alignment and brackets to tighten. The tab on top of the alternator goes past the bracket I thought it was supposed to bolt too before the belt is even tensioned (it is def the right belt I double checked part numbers). And if I push the alternator back towards the motor so the bolt tab lines up with the bracket channel, I only have 5-10mm of movement which isn't right either.
Am I missing parts from the adjustment mechanism?
Can someone post up a pic of what it is supposed to look like. I have a bunch if spare parts so the extra brackets (if any) might be in the box. It also has some air con bracketry (no compressor) so that might be effecting it too.
