I have a 98 1hz. The cooling system is fine but the glow system temp sensor (coolant temperature sensor) isn't working meaning the glow plugs don't stay on for the correct amount of time. I've already got a new sensor and tested it fixes the issue.
The service manual states you have to drain the coolant to change the sensor so I am thinking of anything else I should do at the same time? Is it worth putting a new thermostat in since they are so cheap? Anything else?
Thanks
Thanks
