1997 FZJ80 Oil Capacity
Discussion in '80-Series Tech' started by Beast II, Aug 13, 2003.
  1. Beast II
    Beast II
    734
    Dec 23, 2002
    Now this is probably a very dumb question, but it won't my first so here goes. When changing the oil and filter on a 1997 FZJ80, what is the oil capacity ? I remeber something about dry fill etc in the manual and I wanted to be sure I was right. Is it about 8 quarts ?
    Thank you,
    Matt
  2. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    Somewhere in the foothills...
    Matt,
    Just finished a LOF about 30 minutes ago. 7-1/2 US qts with the small 20004 filter; a little more with the larger filters.
    -B-
  3. Beast II
    Beast II
    734
    Dec 23, 2002
    So, 7.5 Quarts with a Toyota filter as well ?
  4. cary
    cary
    3,109
    21
    May 7, 2003
    [quote author=The Beast II link=board=2;threadid=4319;start=0#msg32090 date=1060813874]
    [/quote]
    Actually with the toyota filter it is 10 quarts. A little known fact is the toyota filter while physically only capable of holding .25 quart, can really hold 2 quarts.
    Seriously, mine holds about 7.75. I'm just aiming for 100 posts before the day is out. :D :D :D :D :D :D
    Cary
  5. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    The 20004 is the small Toyota filter that many of us use. It's more expensive than some other OEM filters but has several features that the anal types that frequent this forum can't resist.
    -B-
  6. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,603
    2,981
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Mine takes 7.5 quarts with a 90915-20004 and 8 quarts with a 15600-41010.
    The extra pint that the 15600-41010 holds ends up all over the front axle housing and block web when you take it off ::) .
  7. IdahoDoug
    IdahoDoug
    8,801
    92
    Aug 9, 2003
    I live on the edge using the anal 004 filter, and filling with 8 quarts. I also use M1, yet change out at a shorter 5k interval. I figure the extra .456789 quart is not an overfill danger, as generally there's a 1 quart allowance, and I hate partially filled bottles of M1 laying around. It is also my life's goal to use up the world's synthetic oil reserves as fast as possible, while keeping John Hocker farting through silk by getting the '004's by the box...
    IdahoDoug
  8. Beast II
    Beast II
    734
    Dec 23, 2002
    Are you guys changing the oil every 3,000 or 5,000 miles ?
  9. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    3K intervals for me.
    landbruised likes this.
  10. Hltoppr
    Hltoppr SILVER Star
    2,020
    Media:
    4
    3
    Aug 29, 2002
    Port of Indecision...otherwise Northern Arizona
    3K here to, Valvoline 10-30, 20004 filter.
    -H-
  11. IdahoDoug
    IdahoDoug
    8,801
    92
    Aug 9, 2003
    5k, Mobil 1, 004 filter, block heater for winter startups.
    IdahoDoug
  12. BMT
    BMT
    325
    Apr 1, 2003
    3K and switching from a K&N to a 2004 filter.
  13. cary
    cary
    3,109
    21
    May 7, 2003
    5,000-7,500 miles depending on my mood. I have to get my money's worth out of the synthetic. :flipoff2: (Can I use the flipoff symbol or is it only registered to Junk? :D)
    BTW, I use the good small filter.
    Cary
  14. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    Cary,
    Feel free :flipoff2: ....... :D
  15. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    5,000 mile intervals using M1 with 04 filter and just switched to 0w40 from 5w30. Sometimes the interval is extended and I don't get concerned unless it's over 7,000 miles.
    C-Dan has convinced me that a new OEM drain plug gasket is the way to go on each and every oil change. There is no (nada, zip, none, nothing) leaking from the drain plug or anywhere else for that matter. I detest leaks of any kind. It has a little grease splatter on the underside from the prop shafts but that doesn't count.
    I'm gonna find Cary and sit on him if the 0w40 doesn't work out. (Like I would know....) :)
    -B-
  16. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    :D 90430-12031 :D
    BTW, lefty-loosey, righty-tighty........ ::)
  17. Jonathan_Ferguson
    Jonathan_Ferguson ★ is in the wrong locale SILVER Star
    1,002
    60
    Jul 2, 2003
    Glen Waverley, Victoria, Australia
    Every 10,000km(about 6,000 miles) with a Ryco or Valvoline Z418 and Castrol GTX 2 20W/50. :flipoff2: Just as the book says. :)
  18. cary
    cary
    3,109
    21
    May 7, 2003
    [quote author=Beowulf link=board=2;threadid=4319;start=msg32325#msg32325 date=1060920297]
    -B-
    [/quote]
    Oh crap, Did I forget to tell you that the M1 0w-40 has been doing horribly, you should change it out immediately!!! :D :flipoff2:
    Seriously, I have about 2000 miles on the M1 0w-40 and no oil consumption. I have ordered and received an oil analysis kit from Blackstone labs and will have the oil checked at 5000-6000 to see how the engine likes it. Watch, they will say that the oil is fine, but I have a coolant leak (head gasket)!!! :'(
    I have also been running the 0w-40 in my wifes BMW 525i, and it hates it. I was using 15w-50 (the original weight recommended by BMW before they changed their minds) and it worked fine except for the lifters making noise when starting. Now the lifters are quiet but the car is using 1 quart every 750-1000 miles. This car is going to get switched to Redline 5w-40 (available locally for $6.25).
    Cary
    ajk970 likes this.
  19. ParadiseCruiser
    ParadiseCruiser
    620
    Mar 27, 2003
    For as often as oil gets changed around here, and the pros and cons of "new gasket" v. "old gasket," I'm surprised no one has ever mentioned Fumoto's wonder valve...
    This is infinitely easier... no more gaskets, no more rounded bolt heads on the drain plug, yada yada. No affiliation, just a more efficient way to change the oil.
    Cheers, R -
  20. Riley
    Riley
    1,613
    10
    Jun 20, 2003
    Fort Langley, BC
    All the dealers around here want to sell me the large filter. So what's the advantage of the smaller filter besides less mess on the shop floor when you replace it?
    DO they both perform the same in regards to filtering?
