If there are shims back by the rear pinion bearing it's a solid spacer setup already , which is good . Some had crush type spacers and a lot of us do not like them since they can lose their preload over time . I got some shims from either Toyota or maybe Kurt when I rebuilt the bearings in mine - they were all toast . I'm not sure how or why you guys could turn the adjuster rings without loosening the carrier bolts first - they are designed to tightly clamp those threaded rings when torqued properly . I'd say someone has been inside it already from the looks of it .
Are those pitting or galling marks on the ring gear ? Hard to tell from the photo , they should be polished solid steel . If you need good gear marking compound , go to a local GM dealer and ask for a tube of it - theirs works quite well and it's the one thing I buy from GM . Pay really close attention to setting up that pinion preload per the factory manual - it's probably the single most important step in setting up those gears . To make things easier , if you have a heavy bench or engine stand you can quickly build a c-shaped frame to hold the gear set solidly to work on it -
Just make sure your frame is heavy material - the LC 9.5" unit isn't light and there are some serious torque requirements when setting up the diff so it has to be stout .
Sarge
Sarge
