I had some carb issues. Here's the background. 1977 australian RHD no smog(not desmogged)
This vehicle had been a non runner for years. I did a rough gas tank cleaning in the beginning. All was well, ran fine for a while. rebuilt the carb when It started stalling. Then all was well. Then it started acting up again. Most likely the float sticking open both time. Too much fuel in the float bowl. Sometimes I thought it was empty but it was so full it looked empty. So i took it apart again to check and I found I bunch of crud in the fuel bowl. See below
So my question is how could all of this get in there so quickly. 2-3 weeks of running? How could this get passed a fuel filter? Can it be coming in through the fuel return with some sort of back pressure? I know I need to do something more with the tank, but I'm not sure I can find a replacement because it's different than US tanks.
Also all fuel lines have been replaced.
Also what other ways can gas become contaminated? Is there any way fuel vapor system could be allowing the fuel to become spoiled?
As always I can't thank y'all enough for the advice.
