I recently purchased a 1985 FJ60 with the original 2F. Seller stated the engine was prone to overheating. I removed the head to have it tested, replace gaskets, replace seals, and have it resurfaced if needed . Once I got it all pulled apart and off the block I got my first real look at the head gasket. I was surprised to see the gasket didn't have holes in all the same places as the head/block. The only coolant holes that were actually open were the 3 at the back of the engine, closest to the firewall. Is this normal??? To me it looks like the gasket was purposely blocking off coolant flow to the front 4 or 5 cylinders.
Could this be the reason for my overheating problem?
