I'm in the middle of rebuilding The front axle on my 93, and I'm going to replace the pads while I've got it apart. They still have some life, but not much. And the passenger side grooved up the rotor pretty bad for some reason. I've read through several brake threads, but I'm seeing conflicting information on which pads to use.
Are the 100 series pads a direct drop in replacement, no modifications needed? They will still use the regular 80 series rotors, or do they use a 100 rotor? Some things said the 100's needed slotted rotors, most said they didn't. If they are a direct replacement, is there any reason not to use them?
I know it's been covered plenty of times, but I'm looking to clear up the confusion.
Thanks
Thanks
