Battery light has been coming on intermittently. Once or twice a day it comes on and stays lit for a few minutes before going off. I found a loose connection where the alternate cable runs to the battery, but have fixed that and it is still happening. Other than the fuses there, any other ideas what to check. The voltage gauge on the dash typically sits one mark down (14.5v ?) from the top (marked 18v), but when the battery light comes on, the voltage shows to be going higher via that gauge.
Could this be a sign of the alternator failing or do they just usually go out completely? Any chance an old battery going out would cause the same symptoms?
