Go Back   IH8MUD.com > General Tech Forums > HardCore Corner
LinkBack (103) Thread Tools Display Modes
Old 02-24-06, 03:44 PM   103 links from elsewhere to this Post. Click to view. #1 (permalink)
BiffS's Avatar
Project Toy-Audi
** Disclaimer** this entire project is intended to be something quite different. I've already heard enough of the "just put in a SBC" and things like that, so it's already been covered: not going to happen.
History:
This is a 1980 FJ 40 Landcruiser that was equipped with a 2F motor. That motor has been sold to a buyer in Louisiana, and is happily sitting under a 74 -FJ 40.
All the original engine related items have been removed and are long gone now. That an the 750 pounds of cast iron wonder. I've been suffering with the carb since I've had this truck and decided that fuel injection is the way to go. No TBI, No TPI, no GM anything.
I've had many VWs and Audis, thus: Project ToyAudi has been born.
Stats: 2.8L Narrow angle V6: 184 BHP @ 4200 RPM. Torque 215 LBS @ 3300 RPM, 400 pound engine complete, Fully fuel injected with a MAF setup, 3 ignition coils and a low clearance oil sump. This motor is intended to get jostled around.
Vehicle: 80 FJ 40 with 4 link front and rear, Fox 18" airshox, HADL driveshafts cut n turned front axle and 1 ton steering gear. Engine will be mated up to the factory 4 speed and T case. (edit: ended up using a V6 5 speed, 4cyl toy doubler and 4speed LC tcase)
Interesting notes: As well as being 350 pounds lighter than the 2F, it's even 14" shorter in length, and 4 inches lower in height. All in all, I figure that I can keep the engine weight down low and more towards the center of the truck.
Progress will be slow and methodical, so please bear with me.
Before:
2F on the way out.
4 rings. . .
Test fit in the bay. note how far back the motor sits with regards to the shock towers.
Side view.
Sans Leaves. . . Link it don't leaf it!
Project ToyAudi: Daily driver duty for a while:Audi 2.8 in a FJ 40.
DD for the Mrs.: PZJ77V RHD for hauling cargo.
BiffS is offline   Reply With Quote
Old 02-24-06, 05:03 PM   #2 (permalink)
Man-A-Fre!!!!
Steve-O's Avatar
Very different, havent heard of this one yet. What will you be doing for adapting the motor to the stock 4 speed? Was the donor vehicle a manual or automatic?
Steve H.
Steve-O is offline   Reply With Quote
Old 02-24-06, 06:32 PM   #3 (permalink)
awp_cruiser's Avatar
"Engine will be mated up to the factory 4 speed and T case. "
That is interesting. Are you going to have a bell housing made? You going to use the factory fuel tank?
AWP
1973 FJ40 -
Rimrock - 2
FJ40 - 0
awp_cruiser is offline   Reply With Quote
Old 02-24-06, 07:18 PM   #4 (permalink)
Eskimo's Avatar
Wow... after messing with the ECU in my 1.8T, I couldn't even IMAGINE where to start on a 2.8 into a non-VAG vehicle.
Rich Q.
FJ - '73 FJ-40 Cruggy - 5.3/4-wheel steer Rockwells/4-link/coilovers/42's
Build thread --> http://forum.ih8mud.com/hardcore-corner/124040-keeping-low-rockwells-k-under-knife-again.html
'04 Avalanche 2500 Lux-o-tow
Eskimo is offline   Reply With Quote
Old 02-24-06, 08:25 PM   #5 (permalink)
BiffS's Avatar
The factory 4 speed bell housing has a machined flat surface on it . It looks like i can get some new holes punched in that will line up with the Audi block.
I'm already running a Jaz pro-sport fuel cell in the back behind the axle.
Donor vehicle was a 1996 A6 Quattro automatic. i can shunt the neutral start circuit and it won't be a problem.
Luckily Canadian motors don't have the additional emissions stuff that US versions do.
Old 02-25-06, 12:24 PM   #6 (permalink)
Waggoner5's Avatar
Keep in mind of all the OBDII parts that need to be addressed like both O2 sensors, pressurized fuel system with vapor purging, etc. Sounds like a cool project. Can't wait to hear the outcome.
Gary
Gary Waggoner
Golden, Co
1989 FJ62 SOA, 502 Mercruiser, ARBs Sold
1987 HJ61 SOA, Cable Locks, 39k miles Sold
1965 FZJ45 Pickup on Slee'd 80 chassis, plan B with 4.7 V8
2003 Tacoma, ARB, OME, SC, TRD Sold
2007 100 series, ARB, OME, Slee'd
TLCA 10689
LSLC 2000
Rising Sun 2007
www.powerplayracing.net
Waggoner5 is offline   Reply With Quote
Old 02-25-06, 02:10 PM   #7 (permalink)
metalonmetal's Avatar
man you got my attention, are you actually located in vancouver or just near it? i'd love to see this setup
drew merryman
even toyota canvas rusts
metalonmetal is offline   Reply With Quote
Old 02-25-06, 08:59 PM   #8 (permalink)
biffs,
That sure looks like a 12v motor to me I worked for auid for 6 years in the usa and the thirty valve motors (starting motor code AHA) don't look like that. In us trim i think they were 167 hp and then 190lb ft of torque. You should really be hunting for a 300hp 4.2l all aluminum v8 from the A8 now that is a kickin motor and would make that 40 stomp!
good luck check out www.034motorsports.com they make VAG stand alone engine management stuff cool guys with some insanely fast 5 cyl audis
jerseyfzj80 is offline   Reply With Quote
Old 02-25-06, 11:03 PM   #9 (permalink)
BiffS's Avatar
I'm located ub by UBC area.
THe engine i believe is an ACK code.
for the AFC engine, the details are as follows for USA version.
  • 2.8L / 169in3 / 2771cm3 displacement
  • Maximum output: 174bhp DIN (128kW) @ 5500rpm
  • Maximum torque: 250Nm (184ft. lbs.) @ 3000rpm
  • Maximum engine speed: 6700rpm
  • Bore: 3.25in / 82.5mm
  • Stroke: 3.40in / 86.4mm
  • Compression ratio: 10.3:1
  • Accurate fuel metering by means of a heated-wire
    air mass sensor
  • Dual stage multi-path intake manifold
    • Short intake path: 380mm
    • Long intake path: 780mm
  • Engine code: AAH, AFC
  • Weight: 355lbs / 161kg
  • Length: 17in / 432mm
Note the weight. That's my major selling point as wellas the fuel injection. I'm also interested in how the torque peaks out at around 3000ish RPM.
I had a 30 valve A4 for a while, and that inspired the selection of this type of engine. I'd love to have gone 30 valve, but i doubt that i could afford one and i would HATE to try to figure out how the drive-by-wire system works.
Anyone got a link for an 8A0 Wiring harness? I've got both Ho2 sensors and the manifolds. I might even run the cats to keep the gassy smell down.
More engine details at www.12v.org
Old 02-27-06, 10:13 AM   #10 (permalink)
That is certainly a different swap!
Just wanted to give you some weight references and power outputs:
I have a 3.8i (231ci) Buick Grand National turbo/intercooled motor that would make about 350ft/lbs tq at 3K RPM stock and 300hp all the way to its low 5400rpm redline. It weighs 420lbs fully dressed with all accessories, parts are relatively cheap on it and having a chip burned for it is only $75 for perfect tuning on whatever gas you have available. With lightweight starter ($90 new) and no a/c it would be be around 380lbs.
An LS1 all aluminum 346ci V8 weighs 480lbs with all accessories and will make 350ft/lbs tq at 2K RPM and pull to 6500rpm+ and make 400hp+ at 5000rpm+.
I hope that engine will have enuf power for the trails. I'm sure with enuf gearing you can do what you want.
'97 LX450 triple lock'd, OME J's, 285 MT, MTsliders,4x4Labs bumper, BBGT35R custom turbo
'84 FJ60 OME 2" lift, 33's "Mr. Hanky" SOLD!
PROJECT: road race RX-7/LS7/T56 575rwhp 10.5@140mph goal
'93 RX-7/LS1/T56 440rwhp/2800lbs 1.13gs 11.41@127.4mph SOLD
'87 RX-7/Buick GN power - 11.6@115mph R.I.P.
gnx7 is offline   Reply With Quote
Old 02-27-06, 01:29 PM   #11 (permalink)
BiffS's Avatar
Useful info to note.
I was trying to keep it normally aspirated, and most importantly fuel efficient as well as injected. The comparisons that i've made are relative to the 2F which came out, so i'm basing my reasoning on that. Plus i'm just a bit bent, so i thought i'd try something different.
original 2F made something like 150 Hp and 170 FT lbs or something like that. I might consider a mild cam or chip to get more out of it if i feel the need, but i think this will be suitable power upgrade over a carbed 2F. I'm also doing away with the power robbing emissions crapola, as this will pass testing with straight pipes, let alone emission equipment.
Progress report:
Didn't get much time over the weekend (helping a friend move) so i've only been able to look at the wiring mostly. The 2F flywheel is about 2 inches larger in diameter than the Audi version. I think i might need to look for a manual transmission flywheel and bell housing as a starting point for mating the two up.
One other discovery is that it will sit too far back in the engine bay if i mate it directly to the LC bell housing, so an adapter plate and stand off from the crank might be a good idea.
I'll post more pics and info this week.
Old 02-27-06, 08:46 PM   #12 (permalink)
bad_religion_au's Avatar
sure you've got 35 more FT lbs of torque, but look where it is in the rev range. the 2f rocks my world because it'll drag a cruiser along at 300 rpm BUT i like your out of the box train of thought, i wish you well with it
What can you do when you wake up and realise you sacrificed everything you ever wanted in life for the sake of progress?
bad_religion_au is offline   Reply With Quote
Old 03-06-06, 07:35 PM   #13 (permalink)
89s rule's Avatar
TLCA# 14198
I want to follow this, very interesting, and very "out of the box" Something I certainly would not do, but its cooler than the usual chevy V8.
'93 FZJ 39K miles - 850/860, Bilies, LED tails, sliders, & 285 MTRs Lightforce 240s waiting on a bumper.
'97 4Runner SR5 - 4x4, leather, Toyo AT, TJM T15, LF 240s.
'63 Biscayne Wgn - Kandy Green & Tweed. Family Wagon 3rd row in the garage.
'89 FJ62 & '83 fj60 SOLD
Erskine College Upstate Cruisers
89s rule is offline   Reply With Quote
Old 03-07-06, 11:39 PM   #14 (permalink)
BiffS's Avatar
Yeah, the low RPM grunt of the 2F can't be matched, that's for sure. In fact, some V8 guys say that a 2F will out soldier a V8 at the low, low RPM. The V of this motor will definitely provide some good low end, as well as provide some useable top too.
It looks like i might have to take a walk on the dark side: This motor is SO short that it will sit extremely far back under the cowl if I don't make some changes. I guess i'll need to think about a SM 465 or 420 or something. . . Dang. . .
check out how low this engine is slung in the bay. there's probably about 10+ inches between the top of the motor and the hood. There's also about 20 inched from the back of where the rad would be as well. The motor is also EXTREMELY low slung in the bay, it looks like i'll have to move my upper contorl arms to make it all fit in.
Old 03-07-06, 11:57 PM   #15 (permalink)
Ramblin Wreck
CruisinGA's Avatar
Not sure where the SM420/465 will help, shifter tower is in a similar location to the toy trannies. (If understand you need to move the engine forward some and keep the shifter far enough back so that it is out of the heater...)
Not to discourage you though, as it seems you will definatly need more gearing than you have already with that engine...
More power to ya
Bailey Quintrell
'74 FJ40--37 Irocks-32 Bolt 'Locks-SM420-ARB-XD9000i-FJ60 PS-MetalTech Cage
'93 FZJ80-DD-P.T. 4wd-locked-5" lifted-snorkel-bullbar-315 AT's
'53 Willys Wagon
ΣΧ
CruisinGA is offline   Reply With Quote
Old 03-08-06, 12:06 AM   #16 (permalink)
BiffS's Avatar
good point. Anyone try doubling the 465 or 420? i have room to spare. . .
Old 03-08-06, 12:44 AM   #17 (permalink)
Advent's Avatar
TLCA# 12717
Thought about adapting a Ranger under/overdrive? That'd move it forward a bit.
Advent is offline   Reply With Quote
Old 03-08-06, 01:03 AM   #18 (permalink)
BiffS's Avatar
No, I've never heard of that one. Got details? Right now i'm researching dual T cases or dual trannies. . . Can't seem to find any dual H 42s out there. THe Toybox is far too spendie for my budget.
Old 03-08-06, 08:53 AM   #19 (permalink)
Advent's Avatar
TLCA# 12717
http://www.man-a-fre.com/parts_acces...20Splitter.htm
It goes between the engine and transmission. It's available in 15 or 25% over or underdrives.
But it sounds like it's more than you want to spend...
Old 03-08-06, 02:58 PM   #20 (permalink)
Kaderabek's Avatar
I own a Cruiser and I own an Audi. Never thought to combine the two. Right on.
TJK
Todd J. Kaderabek
TLCA # 9280, Fairview, NC
Kaderabek is offline   Reply With Quote
Old 03-08-06, 03:26 PM   #21 (permalink)
Ramblin Wreck
CruisinGA's Avatar
Look at www.advanceadapters.com for various overdrives/underdrives
The double tranny thing is difficult unless the second tranny is a non-synchronized unit, as the synchros on these trannies are not stout enough to slow the weight of another tranny mainshaft in front of it.
Bailey Quintrell
'53 Willys Wagon
ΣΧ
Old 03-08-06, 08:26 PM   #22 (permalink)
two thoughts for you:
an nv4500 will add the length/gearing you want.
or... in the gm/chevy 1.5-2.5 ton trucks (3100-4600) the sm420 was bolted to a spicer rangebox or secondary trans that had 1 or two over or under drive gears. might be hard to find but this has the same output as the sm420 and bolts right to the back of it.
cool build-up! carl
fng55 is offline   Reply With Quote
Old 03-09-06, 12:12 AM   #23 (permalink)
hendo's Avatar
looks like you are working hard being light in the engine compartment, why not go light in the gearbox section aswell ,a nv4500 must be heavier than the eng you got, why not got automatic and save some weight
hendo is offline   Reply With Quote
Old 03-09-06, 03:09 PM   #24 (permalink)
BiffS's Avatar
A bit of a change of plans now.
I've decided to go with a Mini-truck tranny and t case using a Marlin adaptor to continue to run my cruiser T case (Doubler). That would provide a 153:1 ratio and dual cases. . .
It would also provide me the added length from the shifter to the engine bay.
-This would acomplish a few things: my nice virtually new HADL shafts would not have to be modified,
- proven toyota tranny
- dual cases
- 6.5" additional length over stock with the extra case.
- smaller clutch and flywheel diameter to better adapt to the Audi engine.
For those that have or have driven the Audi's I'm sure that you'll understand the low end that those motors can put out. I was originally looking for a 2.7 BT but a twin turbo motor on the trail might not be that useful.
I'll pick up the tranny on the weekend, and add the marlin adaptor next week!
Yeh progress!
Old 03-15-06, 02:28 PM   #25 (permalink)
BiffS's Avatar
Have finally got around to getting the tranny and tcase from a mini. Tcase looks good inside, but the 2wd / 4wd shift fork broke during roll pin removal. Not a big deal as the that fork gets de-comissioned anyhow, but it's still a bit of a pain. Marlin dual adapter is on the way now, and a test fit of the tranny indicates that it will push the motor about 8" in front of the firewall. Room good!
Pulled of the bell housing, it is close to a bolt up to the Audi motor. Should require a simple plate to get it up to the mini tranny. I'm looking at the possibility of using the Audi manual transmission flywheel, and adapting the mini flywheel and pressure plate for maximum compatibility.
Also got the wiring sorted out off the harness. Most if the original harness is intact and can be mated up to the original positions of the connectors.
Old 03-16-06, 04:36 AM   #26 (permalink)
ats4x4dotcom's Avatar
When I wanted my 40 "outside the square" I made it 98" wheelbase, and fitted a 400hp and 660ft lb [@ the wheels] 454 mounted 3" further back than standard for balance, with 75 series power steering and 4 wheel disc brakes, and 60 series springs.
Those audi bits have just f%$@#d up a good 40
Darren McRae 95 80 series 1FZ-FE with bits to come
http://forum.ih8mud.com/80-series-tech/207630-project-rooby-80-all-rounder-build.html
ats4x4dotcom is offline   Reply With Quote
Old 03-16-06, 09:31 AM   #27 (permalink)
BiffS's Avatar
to each their own i guess.
Some competition rock buggies use Subaru, Ecotech, even Toyota Matrix engines.
Why not go with a race bred / proven motor when my interest is obviously not to smoke my tires up every rock face that i encounter?
Trust me, my Cruiser can do fine with out Wet Coast terrain as it was, now it gets better!
(and yes, i know the fog lite covers are gay. . .)
Old 03-16-06, 07:28 PM   #28 (permalink)
lowtideride's Avatar
TLCA# 14891
More power 2 ya. Thinking out side of the box is good.
www.NFCruiserheads.org 2RZ-FE 'D 1983 SR5 Hilux...
has had no peers for 50 years...
lowtideride is offline   Reply With Quote
Old 03-16-06, 07:55 PM   #29 (permalink)
concretejungle's Avatar
TLCA# 14646
I think it's rad.
95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 35" truxus, Aussie locker-rear, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . .
Go 80, or go unsatisfied
concretejungle is offline   Reply With Quote
Old 03-16-06, 08:32 PM   #30 (permalink)
bkg
that looks like it's a G52 tranny - if so, it's only going to last to the end of the driveway before you blow the thing up. Even if it's a W56, you're only good for about 180lb/ft of torque w/o risking blowing it up.
For a mini truck tranny behind a v8, you'll need a R150 or 151 (which would be the ultimate)...
Cool build!
Brian K. Gallus
bkg is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/hardcore-corner/81158-project-toy-audi.html
Posted By For Type Date
it is illegal to use a marine VHF radio on land! - BB.BC4x4.COM This thread Refback 10-23-09 08:06 AM
fj40 tub replacement - BB.BC4x4.COM This thread Refback 09-15-09 11:16 PM
33" BFG wheel balancing problems - BB.BC4x4.COM This thread Refback 09-08-09 03:09 AM
Where are they now - 9" full floaters? - BB.BC4x4.COM This thread Refback 08-15-09 08:03 AM
DOM tubing - BB.BC4x4.COM This thread Refback 07-18-09 01:03 PM
Histeer, front u bolt flip kit - BB.BC4x4.COM This thread Refback 07-13-09 08:22 PM
Small Microwave - BB.BC4x4.COM This thread Refback 07-13-09 07:47 PM
July Board Supporter Draw: THREE MORE BC4x4 HATS - Page 2 - BB.BC4x4.COM This thread Refback 07-11-09 03:41 PM
Clean 1989 4runner - BB.BC4x4.COM This thread Refback 07-10-09 10:57 AM
set of 4 - 35 x 12.5 x 15 on aluminum rims - BB.BC4x4.COM This thread Refback 07-09-09 01:56 PM
outboard - BB.BC4x4.COM This thread Refback 06-29-09 10:32 PM
exo insparation - BB.BC4x4.COM This thread Refback 06-22-09 03:24 PM
pro comp xtreme muds - BB.BC4x4.COM This thread Refback 06-17-09 07:09 PM
truck parts and household e-garage sale - BB.BC4x4.COM This thread Refback 05-29-09 12:34 AM
Set of 5 BFG ATs 31 X 10.50 on rims - BB.BC4x4.COM This thread Refback 05-26-09 07:17 PM
Another stolen truck: 87 4runner sas 5am april 17 - BB.BC4x4.COM This thread Refback 04-17-09 12:25 PM
Project Toy-Audi! - BB.BC4x4.COM This thread Refback 04-09-09 11:56 PM
pair of front HEATED seats from VW - BB.BC4x4.COM This thread Refback 03-31-09 02:08 PM
Project Toy-Audi! - Page 2 - BB.BC4x4.COM This thread Refback 03-31-09 11:06 AM
ADD, axles and hubs question - BB.BC4x4.COM This thread Refback 03-23-09 10:23 PM
north shore offroad - Page 3 - BB.BC4x4.COM This thread Refback 03-11-09 06:33 PM
5.5 johnson seahorse CD-17 motor - BB.BC4x4.COM This thread Refback 03-02-09 10:13 PM
looking for tranny - BB.BC4x4.COM This thread Refback 02-26-09 06:55 PM
Landcruiser Parts - BB.BC4x4.COM This thread Refback 02-26-09 10:09 AM
front driveshaft options for new solid axle? - BB.BC4x4.COM This thread Refback 02-26-09 06:42 AM
16' aluminum boat & trl & 50hp merc - BB.BC4x4.COM This thread Refback 02-24-09 12:57 AM
4:10 front carrier wanted with or w/o gears - BB.BC4x4.COM This thread Refback 02-23-09 10:48 PM
Seats for a 60 series TLC What have you? - BB.BC4x4.COM This thread Refback 02-20-09 05:38 PM
Coquitlam VI Season has Opened! - Page 3 - BB.BC4x4.COM This thread Refback 02-12-09 04:56 PM
BB.BC4x4.COM - View Profile: Biff This thread Refback 02-11-09 12:17 AM
1990 blue cherokee laredo part out 4x4. - BB.BC4x4.COM This thread Refback 02-04-09 06:09 PM
Trade only: xterrains 35 12.5 15 (5) for 37+ - BB.BC4x4.COM This thread Refback 02-04-09 10:51 AM
Big clunk that's not a u-joint? - BB.BC4x4.COM This thread Refback 02-02-09 10:55 PM
chain vs gear transfercase - BB.BC4x4.COM This thread Refback 01-23-09 05:09 PM
Brand new Skyjacker Hydro: 9 and 10 inch shocks. - BB.BC4x4.COM This thread Refback 01-20-09 09:22 PM
35x12.5r15 cooper discoverer stt - Page 2 - BB.BC4x4.COM This thread Refback 01-18-09 09:29 PM
Aussi Lockers + Snow/Ice - Page 3 - BB.BC4x4.COM This thread Refback 01-16-09 02:15 PM
TRUCK STOLEN coq center - BB.BC4x4.COM This thread Refback 01-09-09 02:38 PM
FJ 40 Buildup - 4 link front and rear - BB.BC4x4.COM This thread Refback 01-01-09 07:36 PM
Best Articulation lets see it - Page 3 - BB.BC4x4.COM This thread Refback 12-11-08 02:40 AM
wheelin sunday eagle - BB.BC4x4.COM This thread Refback 12-03-08 09:44 AM
90's runner suspention question - BB.BC4x4.COM This thread Refback 11-19-08 10:23 PM
3 - Round toyota emblems - BB.BC4x4.COM This thread Refback 11-19-08 06:15 PM
Used R14 Fiberglass insulation - BB.BC4x4.COM This thread Refback 11-18-08 10:10 AM
oil pan for 4.0 - BB.BC4x4.COM This thread Refback 11-15-08 09:38 PM
Parting out 92 YJ - BB.BC4x4.COM This thread Refback 11-15-08 12:44 PM
gas miser! 1990 Mazda Protoge, 5spd cheap - BB.BC4x4.COM This thread Refback 11-04-08 05:16 PM
Antenna tuners in coq, burn, area - BB.BC4x4.COM This thread Refback 10-06-08 11:31 PM
Used Insulation - R10 and R14 CHeap - BB.BC4x4.COM This thread Refback 09-25-08 02:55 AM
RC crawler - BB.BC4x4.COM This thread Refback 09-11-08 11:14 AM
Found - BB.BC4x4.COM This thread Refback 09-10-08 11:48 PM
Lost bag of clothes - between mission and Hale Labour long weekend. - BB.BC4x4.COM This thread Refback 09-10-08 11:40 PM
set of 37 This thread Refback 09-07-08 11:43 AM
YJ (maybe fit a TJ too?) front bumper... - BB.BC4x4.COM This thread Refback 09-05-08 10:08 AM
Pics of long armed 4-runner - BB.BC4x4.COM This thread Refback 07-17-08 11:54 PM
Blowing header gaskets - BB.BC4x4.COM This thread Refback 07-09-08 03:43 AM
Winching and recovery etiquette. - BB.BC4x4.COM This thread Refback 07-08-08 04:22 PM
New Coil Springs for my Runner. - BB.BC4x4.COM This thread Refback 07-06-08 12:00 AM
how young? - BB.BC4x4.COM This thread Refback 06-30-08 06:05 PM
best poser shots - Page 5 - Pirate4x4.Com Bulletin Board This thread Refback 06-29-08 12:39 PM
Wanted: 4L80 or 4L60 tranny - BB.BC4x4.COM This thread Refback 06-29-08 10:50 AM
FJ40 Ghetto build - Page 8 - BB.BC4x4.COM This thread Refback 06-27-08 07:11 PM
Deliberately parking too close to your vehicle - Page 2 - BB.BC4x4.COM This thread Refback 06-16-08 08:50 AM
Pics of your trucks...sticky?? - BB.BC4x4.COM This thread Refback 06-11-08 03:07 PM
EBI's chromly birf vs Longfields - BB.BC4x4.COM This thread Refback 06-10-08 07:28 PM
EBI's chromly birf vs Longfields - BB.BC4x4.COM This thread Refback 06-02-08 11:56 PM
Do you help others on the trail? - Page 5 - BB.BC4x4.COM This thread Refback 05-31-08 09:11 AM
Construction labourers (2) for my house Mon - Wed - BB.BC4x4.COM This thread Refback 05-25-08 09:52 PM
2nd gen 4runner parts - BB.BC4x4.COM This thread Refback 05-20-08 07:07 PM
NEW bfg AT ko 33X9.5X15 on 5 on 4.5 This thread Refback 05-06-08 01:49 PM
peoples opinions on trail gear ifs eliminator kit - BB.BC4x4.COM This thread Refback 05-05-08 04:24 PM
Lets talk about the CURSED Idler arms!!!!! - BB.BC4x4.COM This thread Refback 04-27-08 03:51 AM
Official Toy link thread?? - BB.BC4x4.COM This thread Refback 04-25-08 03:44 PM
rear coils in fj40 ? - BB.BC4x4.COM This thread Refback 04-24-08 06:03 PM
4runner rear coil lift - BB.BC4x4.COM This thread Refback 04-23-08 05:19 PM
soft top - BB.BC4x4.COM This thread Refback 04-22-08 07:40 PM
Cruiser pts - BB.BC4x4.COM This thread Refback 04-18-08 04:57 PM
Misc Bronco/F-series stuff - BB.BC4x4.COM This thread Refback 04-18-08 01:26 AM
Siding question for you builders - BB.BC4x4.COM This thread Refback 04-14-08 11:39 PM
peoples opinions on trail gear ifs eliminator kit - BB.BC4x4.COM This thread Refback 04-14-08 04:10 AM
2nd Gen. 4runner Drivers side Mirror - BB.BC4x4.COM This thread Refback 04-10-08 10:17 PM
Want to buy Warn 8274 winch parts, What do you have? - BB.BC4x4.COM This thread Refback 04-08-08 09:48 AM
anybody building roll cages in the lowermainland - BB.BC4x4.COM This thread Refback 04-02-08 11:06 PM
parting out 86 f250 - Page 2 - BB.BC4x4.COM This thread Refback 04-02-08 07:04 PM
f250 rear leafs - BB.BC4x4.COM This thread Refback 04-02-08 01:19 PM
Toyota Hilux Crew Cap Pickup - BB.BC4x4.COM This thread Refback 03-28-08 03:34 PM
Useful Antenna Information Every CB'er Should Know - BB.BC4x4.COM This thread Refback 03-26-08 02:16 PM
Toy parts garage sale!! - BB.BC4x4.COM This thread Refback 03-21-08 06:09 PM
running this system for steering? - BB.BC4x4.COM This thread Refback 03-19-08 09:14 AM
Official Toy link thread?? - BB.BC4x4.COM This thread Refback 03-15-08 08:09 PM
Toyota Third Member Question - BB.BC4x4.COM This thread Refback 03-12-08 09:29 PM
Chevy V6 Swap Questions - Page 2 - BB.BC4x4.COM This thread Refback 03-06-08 07:19 AM
Toy runner / cruiser stuff - BB.BC4x4.COM This thread Refback 03-04-08 08:03 PM
JDM engine source - BB.BC4x4.COM This thread Refback 03-02-08 08:49 PM
custom rear tube bumper (toyota) - BB.BC4x4.COM This thread Refback 02-27-08 08:52 AM
ecm compatability? - BB.BC4x4.COM This thread Refback 02-26-08 05:46 PM
Tube doors - BB.BC4x4.COM This thread Refback 02-17-08 02:15 PM
mud king spare tire - BB.BC4x4.COM This thread Refback 02-16-08 11:35 PM
79 Ford truk for parts or whole w/ HP D44 and spare parts truck! - BB.BC4x4.COM This thread Refback 02-14-08 11:27 AM
FUEL TANK 76 FJ40 - BB.BC4x4.COM This thread Refback 02-13-08 08:34 PM
2 This thread Refback 02-12-08 11:01 PM
FJ40 Ghetto build - Page 8 - BB.BC4x4.COM This thread Refback 02-12-08 06:47 PM
Litt sr sak. Audi motor da =) - Medlemsforum This thread Refback 12-18-07 03:37 PM
